01-06-2017, 03:57 PM   #1
HELP! my K-30 get soaked
My K-30 get soaked in the water when I slipped when shooting at the beach, I know my K-30 is weather sealed but the attached lens is not when it gets soaked. I quickly remove the lens, battery, SD card and dry my K-30 after it get soaked. I also stored the battery in uncooked rice, and when the first time I open my K-30 there's green light flashing in the front but it's not turning on, I remove the battery and try opening it again and nothing happens. Is there a chance for my K-30 to be used again? Thanks.
01-06-2017, 04:05 PM   #2
Closed Account
Sorry to hear about your camera. Very hard for us to say whether your camera is " dead or alive." Probably only a service center can tell you for sure if it can be repaired. Good luck.
01-06-2017, 04:18 PM   #3
photoptimist's Avatar
I'd remove the battery, lens, open all the little doors, and leave the camera open (but face down so dust does not collect on the mirror or shutter) where it can dry out for several days or a week.
01-06-2017, 04:29 PM   #4
The camera may simply need a little more time. Keep it in a bowl of rice and check back in a few days. Good luck!
01-06-2017, 05:05 PM   #5
Rice is good.
Also try colour changing silicon gel. Place in a sealed bag to maximise moisture absorption from the camera itself. Once the silicon turns pink you put the silicon in the oven @ 90 degrees celsius for an hour or two (MINUS the CAMERA), then cool then put back into the bag. Repeat until the silicon no longer turns pink. Only then try the camera with battery inserted.
01-06-2017, 05:25 PM   #6
Not a Number's Avatar
Your profiles lists the Philippines as your location. I imagine it is rather humid to begin with. Drying out will take a lot longer as the rice might be somewhat saturated to begin with. You may be able to buy disposable dehumidifier packs The ones they sell in the US have some desiccant that turns into a liquid as it absorbs water so are not reusable. They have a reservoir on the bottom to collect the liquid.
01-06-2017, 05:43 PM - 1 Like   #7
AquaDome's Avatar
Did you put the SD card in? The camera will not turn on without it.
01-07-2017, 02:50 PM   #8
QuoteOriginally posted by AquaDome Quote
Is that so? My K-30 turns on without an SD card.
01-07-2017, 03:33 PM   #9
PDL
Not True
I just pulled my K20D off of the shelf and verified that it turned on. It does not have a SD card installed, your statement is false.
01-07-2017, 04:21 PM   #10
Sorry to tell you this but even if it lights up again the salt will finish it off in a year or so. Any way good luck.
01-07-2017, 05:44 PM   #11
QuoteOriginally posted by Wild Mark Quote
Rice is good.
QuoteOriginally posted by dcshooter Quote
If the camera fell in salt water, then it would probably be a good idea to rinse everything off with distilled water before drying, or you are likely to get all kinds of corrosion to metal parts. If there is dried salt in the mirror box, gently swab it away with a microfiber dipped in distilled water.
Thanks I'll try all your suggestions,hope my K-30 works again. I forgot to mention how can I remove the moist/droplets in the lens?, thanks again.
01-07-2017, 05:52 PM   #12
QuoteOriginally posted by vinzxalvin Quote
you have to rebuild that lens that's how.Maybe dcshooter can help you
01-07-2017, 05:54 PM   #13
A little harder if it is WR lens. When the droplets 'dry' it will leave a resdiue of some type. That will be bothersome in taking pictures (it might degrade image quality). The alternative is surgery (to clean the lens).
01-08-2017, 07:30 PM   #14
QuoteOriginally posted by niceshot Quote
Thank you.
01-08-2017, 09:25 PM   #15
AquaDome's Avatar
QuoteOriginally posted by lithedreamer Quote
Oops. I'm thinking about when the door is open.
battery, camera, k-30, lens, pentax help, photography, troubleshooting
How to get K-30 Service Manual JoseFF Pentax K-30 & K-50 1 06-03-2016 05:00 PM
Need help I want flash for my K-30 that...... WGBJR Flashes, Lighting, and Studio 12 09-04-2014 04:10 AM
I'm waiting for my K-30 to come in mail. Did I get the WR 18-55mm lens?? spectamaniac Pentax K-30 & K-50 4 02-15-2013 03:42 AM
HELP I can't get my 50 off my macro teleconverter! shaolen Troubleshooting and Beginner Help 2 07-21-2012 09:20 PM
K-x soaked - OMG - Nooooo!!! emmandkev Pentax DSLR Discussion 29 02-24-2010 03:02 PM
All times are GMT -7. The time now is 07:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
