01-08-2017, 01:03 PM   #1
tatuchelly's Avatar
Pentax Zx-50 Help!!!
Hi, I have had this Pentax film camera for a couple years now. I have finally got some film and read the entire manual two times trying to understand how it works. I think I have everything down to the T and I go to take a picture and nothing. The only thing that happens when I press the shutter button fully down is that the camera rotates right and left and tries to zoom on its own. I am pretty sure that the film is loaded right. I am not sure what is going on. Help.
01-08-2017, 04:21 PM   #2
foto guy's Avatar
Others here can help more than I, but here are a couple of simple things to try:
1. When you press the shutter button, make sure not to point it at a scene without any contrast/objects, such as the sky or a blank wall.
2. Try another lens if you have one.
01-09-2017, 01:34 AM   #3
Alex645's Avatar
a) Is the frame counter on the top right on number one?
b) Do you have the aperture ring on the lens set to "A"?
c) You say the "camera rotates right and left and tries to zoom on its own". Do you mean that the focus ring on the lens is trying to focus and when it does this the image breathes a bit larger and smaller (vs. actually zooming in and out)?
01-09-2017, 03:15 PM   #4
Sounds like the aperture motor gear failure. The gear is plastic and over the years it deteriorates and fails.
01-09-2017, 07:29 PM   #5
tatuchelly's Avatar
Yes there is a 1 for film. The A is set and the front part turns.
01-09-2017, 07:31 PM   #6
tatuchelly's Avatar
Is there a way if it is deteriorated to make it work manually and not use the easy automatic settings?? I really hate to toss it and not even get a chance to use it. I had my heart set on taking pictures with this thing.
01-10-2017, 12:40 AM   #7
Alex645's Avatar
On the front of the camera is an AF/MF switch to go from auto focus to manual focus. Try switching it to MF and see if it will let you manually focus and take the shot.
01-10-2017, 04:20 PM   #8
tatuchelly's Avatar
I will try this. Thank you
camera, film, not taking picture, pentax, pentax help, pentax zx-50, photography, shutter button, troubleshooting, zx-50
Pentax ZX-50 Shutter problems PhotoMajor8 Pentax Film SLR Discussion 3 02-03-2016 08:59 AM
Pentax zx-50 image problem Kaybananapudding Pentax Film SLR Discussion 4 07-19-2015 07:13 AM
Pentax zx 50 KathyP29440 Pentax SLR Lens Discussion 4 03-30-2015 03:14 PM
help with zx-50 idler Pentax Film SLR Discussion 4 05-20-2009 02:42 PM
Pentax MZ-50 (ZX-50) with SMC-M lenses derius Pentax Film SLR Discussion 8 02-28-2008 06:12 PM
All times are GMT -7. The time now is 03:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
