Thank you for all the replies, and to all my 4-eyed brethren, I feel your pain!!!!
I'm shooting exclusively in MF because my K30 succumbed to the dreaded aperture block failure so I'm limited to lenses with aperture rings, and, therefore MF. And actually, is this correct? Are there any AF lenses with an aperture ring?
FWIW, the lenses I own are a Samyang 35mm f1.4, Samyang 8mm f3.5, Pentax K50 f1.4 and a Pentak A35-105mm f3.5, Takumar 200mm f5.6 (I rarely use this one...). And my flash is a Yongnuo YN 560 III
I have attempted many of your wonderful suggestions all with varying success...
Liveview: I can't get comfortable taking pictures this way, I especially dislike the delay after clicking the shutter which inhibits quick fire shots. That being said, under certain circumstances I do use this method and when magnifying on the screen my focus accuracy is pretty reliable.
Prefocusing: I use this technique but it isn't something that's is practical when I'm quickly grabbing my camera for an ephemeral moment.
Cycling focused and unfocused: This is what I do most often, combined with spray and pray... It has probably produced my greatest success but still with a very poor keeper rate...
Macro: I don't shoot macro, ever.
I really like the Catch-In-Focus idea, I'll definitely give that a try.
Sounds like I should attach my flash more frequently too, makes sense.
I will also dial in my AF fine adjustment,
BUT, the aftermarket focusing screen I installed is
not shimmed, does that negatively impact the AF accuracy of the camera??? Instead of shimming the screen could/should I just compensate through the in camera AF fine tuning?
Also, regarding aftermarket focus screens, I initially wondered what the heck the point of the S screen was, but as some of you explained and after actually reading the product description I think this might be a good option.
Here are some good examples of photos where I feel like I "missed it"... Unfortunately because I'm using an aperture ring there's no F Stop data. Also, I think the final pic is a good example of my low light challenge (and white balance...), often I'll intentionally underexpose with a quicker shutter speed and lighten the image in PP.
1/50, iso500 6 by , on Flickr
1/100, iso800 4 by , on Flickr
1/40, iso400 2 by , on Flickr
1/125, iso3200 3 by , on Flickr
When my subjects aren't moving and I have the time I'm pretty pleased with my results though!
1/60, iso400 Beer brewing by , on Flickr
