Originally posted by SpecialK Here's a shot with a prime (DA 21). Not good.
But DA 21mm is a special case. It is designed for completely other priorities than taking photos of paintings. It is a pancake lens, with low aperture, it is wide angle. Yes, it has distortion. But I wouldn't recommend using a lens wider than 35mm for reproduction/documentary purposes. Even the DA 35mm f2.4 has some distortion. The limited DA 35mm f2.8 macro is better. Something in the range of 50-85mm would be better still. I don't think anyone here is recommending the DA 21mm as a great lens
for this purpose (I quite like the DA 21mm, though! For landscapes, nature, street, city.. Great colors and contrasts, super compact for travel)
Of course some lenses are better suited than others. But to get the best distortion characteristics you would use a normal or short telephoto macro prime. Working distance is important, as well. Shooting from really up close will always exaggerate lines, even if the lens itself would have highly corrected distortion. And by definition, wide angle lenses will be used at a closer distance than telephoto.
So, OP using 18-55mm at around 50mm+ or using a 70-200mm around 70-85mm are decent choices. Using aperture of around f8 and ISO 100 are good, too. 2sec timer and EV +/- (to add a touch of brightness) would nail it. But the main problem in OP's question is distortion (can be minimized with right lens and good digital PP) and the lens not being aligned with the painting.
SpecialK's example is using a lens with notorious distortion and it doesn't look that terrible, because the setup was good. Now, using the right lens with that setup would be perfecto.
