Originally posted by awa355 Many articles refer to upping the ISO to allow an increase in shutter speed. If my Tv speed is set to 1/1600, doesn't the camera use that speed regardless of whether the ISO is set at 100 or 3200?.
Yes. It would shoot at 1/1600, and try to adjust f/stop and iso (if auto-iso is enabled) to balance the exposure. If you have auto-iso disabled, it would try to adjust the f-stop only to balance the exposure. No matter what, in Tv mode, the shutter speed will be whatever you set it to.
As to why the articles are suggesting you increase the iso.... suppose a 'proper' exposure was iso100, 1/200s, f/4. If you just up the shutter speed (pretend you're in full Manual mdoe) and shoot at iso100, 1/1600s, f/4, your image will be very dark. So the suggestion is to up the iso one stop for each stop of shutter speed you add. All the following would work:
iso100, 1/200s, f/4
iso200, 1/400s, f/4
iso400, 1/800s, f/4
iso800, 1/1600s, f/4
As we move down the list, we gain motion stopping power, but we'll take a hit with a noisier photo (with the caveat that iso800 is still pretty high quality on any modern dslr
). The f/stop could also be changed to let in more light at the 'cost' of less Depth of Field. All three variables, iso, f/stop, and shutter, are a compromise in one way or another. Choose the compromise that works for your photo, and choose the shooting mode (Tv, Av, TAv, M, etc) that lets you work the variables in the most convenient way.
