Pentax K7 front / back focus
Hi all I tried to adjust the front / back focus on various lens on my Pentax K7 & have tried 2 methods . 1 is where you print off a chart & set @45 degree & take photos & adjust the fine tuning for focus point (35 in menu) . The other way I did was the Dot method where you put a lens test card on a wall then put camera on tripod and do auto focus & switch to manual& watch auto focus light etc.( I found this way on you tube).
With both systems I tried I have gone from +10 to -10 ( 10 is the max in the +/- range ) & all seems to be the same including zero.
All tests were done on a Tokina 28/80 f2.8 AT-X Pro lens at both 28 & 80 f2.8 flash & tripod with a remote shutter release .
What gives do may people out there worry about it or what?
Thanks
