02-03-2017, 12:25 PM   #1
trying to remove broken foot of Pentax 360 flash to fit new one.
Hi everyone, I have a replacement foot for my Pentax 360 flash and I am trying to change it. So far I have unscrewed the four outher screws and removed the base unit. I have removed the four inner screws and thiough the foot is now loose I can't remover it to put the new piece. How do I release what I believe is the locking pin that is sticking up inside and presumably is stopping me remove the foot? Thanks for your help.
02-03-2017, 01:24 PM   #2
I just took the foot apart on mine. Once you unscrew the four inner screws, which are also holding some metal strips, the base should easily separate. Just to be sure, we're talking the first generation AF 360FGZ?
02-03-2017, 03:47 PM   #3
Just pulled mine apart and had a quick look.
The locking pin should not be an issue but a blob of solder on one of the other pins may be your problem as it would not fit through the hole.
02-03-2017, 06:34 PM   #4
MSF
QuoteOriginally posted by clickclick Quote
Hi yes it's the first generation Af 360 fgz. The foot separates partly and then won't move more. I don't know what else I can do as it is certainly fixed somewhere and i don't want to force it as i may damage it completely.
02-03-2017, 06:49 PM   #5
is it hanging on the metal strips that go down the sides? The metal pieces with two screws each also go down the sides of the foot and kinda hook in near the bottom of the foot. Are they grabbing the foot and only letting it move a little bit?
02-04-2017, 03:23 AM   #6
MSF
HI, no I don't think so, it appears to be fixed/jammed/connected somewhere in the middle. Does anyone have any images of how it looks with the foot removed and the metal pieces hanging down? I am going away for the weeknd so I will try again on Monday with a clear head. Thanks
02-04-2017, 03:14 PM   #7
Ok, I went the extra step and removed the four black screws, the foot literally fell off and the pins remained with the base.
So my previous thoughts about solder blobs was wrong.
Unfortunately I can see nothing which would cause your problem. I can see no reason the metal spring things would jam but you could try sliding the foot into a hot shoe or flash stand to see if it helps.
PENTAX Q  Photo
PENTAX Q  Photo
PENTAX Q  Photo
camera, flash, foot, foot of pentax, pentax, pentax 360 flash, pentax help, photography, screws, troubleshooting
trying to remove inner barrel Tamron 2x MJSfoto1956 Troubleshooting and Beginner Help 12 05-20-2014 01:03 PM
ME: Trying to remove top cover but can't remove knobs Capslock118 Pentax Film SLR Discussion 10 08-06-2011 11:30 AM
Trying to rewind/remove the film in a Pentax ME Super nady94 Troubleshooting and Beginner Help 7 10-28-2010 12:24 AM
Can we set the internal flash of K-7 not to flash while connecting wireless with 360? raider Flashes, Lighting, and Studio 12 11-15-2009 09:31 AM
New guy trying to decide on a flash boyscout Flashes, Lighting, and Studio 26 02-14-2009 09:10 PM
All times are GMT -7. The time now is 11:41 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
