Originally posted by Vicioustuna2012 Thanks so much for the advice, but I'm a total noob, so some of this is greek to me. Unfortunately, I only have the one camera.
You can adopt the same strategy with one camera aswell.
The change from night to dawn will be a bit trickier though.
The basic problem is that you want the images as identical as possible. To avoid unneccesary post processing. That is why all settings should be manual. That way you can add the same corrective settings on a large number of images and recive the same result on them all. Using any automation means having to check each image to make sure it has all the same settings... However this adds a new issue, the same settings can not capture a scene at both sunset and during the night with proper exposure.
So you are going to have to change, either manually or automatically. Most people here seem to want to promote automation for camera settings, something I am strongly against, for the reasons above and for the simple fact that you might get such a great error that you have to scrap the entire image...
I would recommend testing your setup in every way you can, my guess is that you want the night sky to move during the night shots... Positioning yourself so that the milky way is visible often provides the best results. You also want to check what ISO settings to use on the k-30 I would say 1600 or lower. The interval you choose has to be long enough to allow proper exposure when it is dark at it will get. Having a 10 second interval if the camera needs 15 seconds for exposure is not that smart
You have additional problems, going for something like this requires many images, the k-30 produces dng raws at around 15MB if I remember correctly. Going for 12 hours would require aprox 2900 images if you go for one every 15 seconds... That is around 45 gigabytes. So minimum a 64GB card is needed, does the k-30 support sdxc? And it is also more than 2000 more than the k-30 can take on a single charge. Can you charge it while taking shots?
Additional problems.
You need to keep the interval the same, some remote that can do interval shots is required or using the built in function... Unless you want to press that button every 5-10-15 seconds for 12 hours...
