02-10-2017, 12:26 PM   #1
Vicioustuna2012's Avatar
Used k-30 with lots of dust inside.
I just bought a k-30, my first DSLR and I love it. I do have a small issue though. there's quite a bit of dust is the body, and a little on the sensor. It is becoming quite a bother, specifically when doing Macro shots. My main question is this: How expensive would it be to have this thing sent off to be professionally cleaned? Does anyone know a round-about figure?
02-10-2017, 12:31 PM   #2
$50 to $75. I'd try to get it done locally if possible, any camera store should be able to.
02-10-2017, 12:39 PM   #3
It's super easy (and faster) to clean it yourself, too.
02-10-2017, 12:47 PM   #4
35mmfilmfan's Avatar
Before you send or take it for cleaning, try using an air blower (apparently Giotto make a well-regarded model) and just blow away the dust. This thread contains more info :Recommendation of a blower to clean sensor? - PentaxForums.com
02-10-2017, 12:50 PM   #5
The Squirrel Mafia's Avatar
Like already stated, get a Rocket blower & try that out first.
If not.....
Sensor & Camera Cleaning | B&H Photo Video
^ I've had to resort to using swabs with liquid on my K-50 & former Sony A200 cameras. Just have to be very careful & have some patience. I use a rocket blower after that & the sensor is as good as new.
Now if the camera is completely dirty on the inside, then maybe a professional cleaning service would be the best thing to do.
02-10-2017, 01:19 PM   #6
QuoteOriginally posted by The Squirrel Mafia Quote
If not.....
Well, it's hard to say how dirty it is because I have no basis for comparison. This is the first DSLR I've ever owned, so I don't know how much dust is acceptable/inevitable or how much would be excessive. I can say this, I've managed to get the sensor relatively clean a few times already, but dust keeps getting back onto it...I'm assuming because there is visible dust stuck on other parts of the inner housing. Also, the dust cleaning shaker function is virtually useless apparently.
02-10-2017, 02:31 PM   #7
Des
Des's Avatar
QuoteOriginally posted by Vicioustuna2012 Quote
Not completely useless, but the ultrasonic system on the flagship models works much better.
I don't think a rocket blower will solve your problem, because it will just blow the dust around inside the chamber. Get a professional clean, and they should clean the mirror box as well as the sensor. If there is dust under the focusing screen, they can do that too (it's not a DIY job for a novice). The longer you leave it, the more chance that the dust will stick and then the problem will be worse.
Once it is clean you can do maintenance cleans yourself. A rocket blower is then more useful, a silicon pad kit (Pentax or Dust-Aid) if that doesn't work, and a wet swab kit as a last resort. Dust-Aid have a good starter kit with both a pad and swabs. A loupe with LED lights is handy too. The important thing with dust is to check regularly and keep on top of it if you have a problem.
02-10-2017, 02:44 PM   #8
pres589's Avatar
I was a bit of an idiot once and used a can of air to try and clean out the mirror box on my K-5 II. Bunch of junk blown onto the sensor and the focusing screen. Tried to clean it on my own and was unsuccessful after buying swabs and cleaning solution and watching videos on how to do it myself. It was better but not great. Had it in to a local shop for cleaning; I think I left it there for a few hours. $25 later and the sensor was great, the focusing screen not so much.
I've learned to not leave the body open much more than I have to when changing lens, always have a lens mounted, and not attack the thing with air if I think I have a dust issue.
blower, camera, dslr, dust, film, k-30, k-30 with lots, lots of dust, pentax help, photography, rocket, sensor, store, troubleshooting
Dust inside my K-50 LCD EdithCosmos Pentax DSLR Discussion 9 04-15-2014 06:42 AM
DA 50mm 1.8 with dust inside? stillshot2 Pentax SLR Lens Discussion 3 01-06-2014 10:41 AM
K-30 # of AF sensors used scottike Troubleshooting and Beginner Help 5 07-01-2013 08:51 PM
Dust or air bubbles inside lens (with picture) Tomm Pentax SLR Lens Discussion 19 05-02-2012 04:59 PM
Lots of dust, but where? vanakaru Pentax K-5 & K-5 II 13 03-27-2011 07:39 AM
All times are GMT -7. The time now is 04:56 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
