02-10-2017, 08:30 PM   #1
Vicioustuna2012's Avatar
K-30 catch in focus function not working
Okay, I've used the "catch in focus" feature before, but today I decided to use it to take some macro shots and I can't get the thing to work. I've tried everything. At first I thought it was just because I was using a macro tube, but I mounted my 50mm prime normally, and it still isn't working. Also, the little focus indicator beep with the red square isn't showing up either.
Some info:
  1. I'm shooting in manual as I only have legacy glass (SMC-m primes).
  2. I have the camera set to AF.S.
  3. Catch in focus is on (2).
I don't know what else to check. Is there another setting that might be turned on that would disable CIF?
02-10-2017, 08:54 PM   #2
luftfluss's Avatar
Catch-in-Focus Tutorial - Articles and Tips | PentaxForums.com
02-10-2017, 08:59 PM   #3
Otis Memorial Pentaxian
QuoteOriginally posted by Vicioustuna2012 Quote
Focus mode switch to AF-S position? AF-S in custom settings set to "focus priority"?
Your macro tube may be a problem too. IIRC, your camera requires that a mount that conducts electricity be present for CIF to work. Most extension tubes are either painted or anodized and are not conductive.
02-10-2017, 09:07 PM   #4
...also...are you set up for AF on shutter half press or back button only?
02-10-2017, 09:26 PM   #5
Well, I never could find out what was conflicting, so I just reset all settings to default and started from scratch. That seems to have worked :-)
camera, catch, catch in focus, focus, focus function, k-30, macro, pentax help, photography, troubleshooting
HELP! Auto-focus on K-x *suddenly* not working! ohaya Troubleshooting and Beginner Help 6 03-27-2016 08:15 PM
Nature If you can not catch in focus... micromacro Post Your Photos! 7 03-13-2015 07:35 AM
Kx Catch-in-Focus not working duetto96 Troubleshooting and Beginner Help 25 11-25-2013 10:02 AM
Catch in Focus on K-30 with... BigJPR Troubleshooting and Beginner Help 4 07-29-2013 08:54 AM
catch in focus not working steve7cat Visitors' Center 10 05-22-2013 08:27 AM
All times are GMT -7. The time now is 05:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
