Originally posted by TaoMaas I'm going to vote for light reflecting off the sensor, too. When you see that a lens was "designed for digital photography", many times that means the rear elements of the lens were coated to help prevent flare from the sensor. It wasn't a problem in film days so most lenses from that era don't have that. It's been my experience that this only shows up under certain conditions and you seem to have found one.
A quick update for you, and others in this thread (by the way, is there a way I can update my thread where everyone who posted will get a notification?):
Anyway, I found out the culprit. It wasn't light off the sensor, well, not exactly. It was the macro extension tube I was using. There were some slightly too shiny surfaces inside, and from doing extensive research I found that these surfaces can cause non image forming light to bounce around in the tube and do this...even though there is no light leaks.
To fix it, at first I tried simply taking my macro photos with a black background, and that helped, but not completely. Then I found a nice thread on flickr from some real geniuses ( I would link to it, but I don't know the rules on links to other sites...is that okay?). They suggested I add some baffles made from black card/construction paper to the tube at each end. So, I cut some Doughnut shapes out of the black card with a fairly large hole in the middle (larger than my largest aperture, but smaller than the original opening) to cover any shiny surfaces/I guess keep light from bouncing. I didn't really measure anything, just kinda eyeballed it. I didn't even use glue, but rather just cut the things so that they tension fit into the tube.
So far, it has worked beatifully! No more ghosting. Check it out:
