02-14-2017, 11:24 AM   #1
SMC Takumar 50mm f1.4 problem
I have SMC Takumar 50mm f1.4, I bought it as a pre-owned. I'm using it along with my Canon 60D. However, I couldn’t put focus on it as the aperture ring slide is stuck for some reason. Any help or simple solution?
Canon EOS 60D  Photo
Canon EOS 60D  Photo
02-14-2017, 11:34 AM   #2
Not a Number's Avatar
What do you mean? The auto/manual switch that shows in your photo on the left hand side just above the silver adapter ring? On most of the auto lenses there is a small pin/button on the rear mount. That needs to be pressed in to release the switch. It should get depressed by the adapter or camera mount when you screw the lens down.
Try dismounting the lens and pressing the button in with a finger nail (it only sticks out about 0.5mm) and see if you can move the switch.
02-14-2017, 12:59 PM   #3
QuoteOriginally posted by dcshooter Quote
Meter coupled Takumars have a little pin on the bottom that has to be depressed for the a/m switch to work. Check that the adapter you are using is depressing it fully. Shouldn't affect focusing, though. The bent filter is troubling; if you can't turn the focus ring, then it suggests the lens was dropped, denting the helical.
I know about the auto/manual switch and it did move. However, the images still resulting not focus. I meant the ring just above the a/m switch that didn't move. It did move just a bit but need a great effort to slide it to the point it broke my skin :/
02-14-2017, 04:23 PM   #4
ripper2860's Avatar
The ring above the A/M switch is the aperture setting ring. If it is bound that tight, then there is obviously issues with the lens. When you focus, does the lens barrel actually extend and retract? Can you remove it form the Canon mount and confirm the rear element is not askew and is actually moving with focus. The lens looks like it's a bit rough condition-wise (looks like the filter / filter ring is bent) although the front glass look OK) and it may have been dropped, etc., causing it to not work properly.
02-14-2017, 07:54 PM   #5
Just1MoreDave's Avatar
Beer tasters!
If you are lucky, only the filter rim is bent. There are lots of instructions around for disassembling this lens but they all start with unscrewing the "name" ring via the filter threads. So if the filter threads are bent, you'd have to fix them first.
02-15-2017, 11:40 AM   #6
QuoteOriginally posted by ripper2860 Quote
Yes, that's what I said the aperture ring stuck. I finally able to move it but with a pipe wrench :/ carefully.
When you focus, does the lens barrel actually extend and retract? --> no, it did absolutely nothing. I'm assuming it's broken and the previous owner did not tell me anything about this.
I'm still able to take shots but it's a bit difficult since I have to position myself (since there's no lens retraction movement) to the object (more/less focus from 3 ft away but that's it).
04-05-2017, 01:47 AM   #7
kroal's Avatar
Hi everyone. Few days ago I have bought Super Takumar 50/1.4. Do I need to lock or remove aperture ring pin (on the rear side of lenses). Will it make any problems during using on camera or during installation/deinstallation? Thanks.
04-05-2017, 08:57 AM   #8
No, that lens should be fine on all Pentax DSLRs. The pins won't hit anything. You will need to move the AUTO/MAN switch to MAN or M to change the aperture. But you can move that switch at any time.
50mm, camera, f1.4, pentax help, photography, smc, smc takumar 50mm, takumar, takumar 50mm f1.4, troubleshooting
SMC Takumar 50mm F1.4 screw mount M42 vs XR Rikenon 1:1.7 50mm vs Smc pentax-A 1:2. 5 pgaikwad Pentax SLR Lens Discussion 11 11-29-2015 12:56 PM
Help : problem with the SMC Takumar 50mm f1.4 redcat Pentax SLR Lens Discussion 11 06-09-2015 12:33 AM
Battle: SMC Takumar 55mm f1.8 VS Pentax FA 50mm f1.4 on the Q EarlVonTapia Pentax Q 13 09-11-2014 07:56 PM
SMC Takumar 50mm/1.4 problem jaieger Pentax SLR Lens Discussion 11 09-05-2010 03:48 PM
For Sale - Sold: SMC Takumar 50mm f1.4 Mile High Sold Items 3 01-09-2009 04:43 PM
All times are GMT -7. The time now is 02:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
