I just found this forum, and somewhat surprised that I have not seen it. I found it when looking for some Pentax lens issues via google. I've been on several camera forums for decades and for some reason have not stumbled on this one.
I posted this on Rangefinder Forum and APUG and if you don't mind I would like the opinions of the folks here, as there appears to be a lot of knowledge here.
Here's the issue, to make a long story long ...
My "main" camera for decades has been a Pentax K1000.
This is a first generation 1980s vintage Japanese model, all metal, well broken in and until a couple of years ago performing flawlessly. It's the one I feel very comfortable with and I can shoot it instinctively. It's never been physically damaged or even dropped onto a hard surface that I know of.
A few years ago some of the slides I shot on a trip to some of the National Parks came back disappointingly soft. This was shooting with an Ozunon 28-135 zoom of 1990s vintage which until then had been tack sharp. I did a quick test roll at the time which was really inconclusive.
To be sure, I picked up a Takumar 28-80 zoom at a local camera show, shot with that for a while with what I considered good results, and blamed the issue on the Ozunon zoom.
Fast forward to a couple of months ago. A roll I shot with the Pentax zoom came back with some disappointingly soft images, mainly those with images off in the distance where I would have focused on infinity.
I decided to do some more rigorous testing and I would like to hear what the gang here thinks.
First of all, two "control" images are at the very bottom of the post. These were taken of the same subjects but not at the same time. I'm including them to show what I consider "normal" and what I'm expecting. The control images were shot with the Mamiya SD rangefinder but well before the test roll on the Pentax.
All of these images were (re)scanned with the KM SD IV at full 3200 resolution, absolutely no sharpening or photoshopping at all. These are all 500x500 full size crops and all show the grain very well. For the real-world shots on all but the control, I centered on what I and the neighbors call "the big honking nest" in the trees in the woods to the rear. The nest was center-left in the control image.
K1000 with 50mm f2.0 prime lens f16:
This one above was taken with the lens set hard to infinity. When comparing with the control image below it appears a wee bit softer to me, but when viewed as a whole image on the screen, there's really no difference. The image appears normal when viewed normally.
Test target 50mm f2.0 prime lens f16:
This is the test target at maybe 6' or so, f16, daylight, manually focused (I did wear my glasses!)
. It looks very normal to me.
K1000 with Takumar-A 28-80mm zoom:
28mm f16:
The shot above was at 28mm with the focus set hard to infinity. Comparing it to the control photo and the prime lens photo above, it appears to be to be somewhat softer. When viewed at a normal size on the monitor it still looks quite normal.
80mm f16:
This shot above was zoomed out to the max with the focus set hard to infinity, f16. To me, this looks unacceptably soft. When viewed on the monitor it's normal or near-normal, but a 8.5x11 print does appear soft to me.
80mm f5.6:
This is overexposed. I wanted to see what it would do in the middle of the f stop range so it was f5.6 at 1/1000. The softness is REALLY showing here!
K1000 Ozunon 28-135 zoom:
I'm not posting the 28 or 50mm Ozunon shots since they look near normal but when I zoom it way out to 135, the softness is unacceptable at f16 and UGLY at f5.6!
135mm f16:
135mm f5.6:
Test target:
The shot immediately above is with the Ozunon zoomed out to 135 at about 10' from the target. It looks normal to me. It was carefully focused while wearing glasses.
I'm not really sure what my conclusion is, and I would appreciate other opinions. I'm leaning toward thinking I might have a bad body but I'm not sure. The prime kit lens, which I really don't shoot with that much, appears to be near-normal at worst but both zooms are producing unacceptably soft images.
"Control" photos:
Not the same roll, obviously, not the same light, and not the same day. These were taken with the Mamiya SD rangefinder, match-needle exposure on the outside shot, exact exposure not remembered but something like 1/500 between f11 and f8 or so. The test target was done indoor with fllash some time before.
Thanks for any advice or opinions, gang!
My "main" camera for decades has been a Pentax K1000. This is a first generation 1980s vintage Japanese model, all metal, well broken in and until a couple of years ago performing flawlessly. It's the one I feel very comfortable with and I can shoot it instinctively. It's never been physically damaged or even dropped onto a hard surface that I know of.
28mm f16:
80mm f16:
80mm f5.6:
135mm f16:
135mm f5.6:
Test target:
"Control" photos:
As an update since I first posted this on the other two forums (fora?) one of the users suggested I do a "focal plane test" shooting something like a brick wall and seeing if the focus I see is indeed what I get. Another off-line comment seemed to think that the infinity stops of both zooms are bad but that of the prime looks good. Second opinions on both of those are appreciated as well.
