Originally posted by jpzk Those images are actual Print Screen shots (direct from computer monitor) while viewing with FastStone viewer. The saved images were then saved as TIFF files and uploaded to Flickr.
I'm coming a bit late to the party, but I can confirm that by default, FastStone displays the embedded JPEG. Depending on the quality of the embedded JPEG, you may or may not see banding and other artifacts. I say that because my K200D embedded a really high quality JPEG in its RAW files. Banding and such was rarely evident. This is not true for my K30.
I use FastStone extensively - it's my browser of choice.
These days, I mostly shoot RAW+JPEG, so when I'm browsing/culling, I look at the JPEGs. If I want to perform simple edits for quick and dirty crops, I will edit the JPEG directly using FastStone. If it needs more sophisticated processing, I will work on the RAW using one of several Raw converters ( usually PDCU or DxO , then Elements if I need to work with layers ).
The fact that FastStone shows you the embedded JPEG is a big advantage - it makes accessing/displaying files so much faster. Others, with a different workflow may not like this feature.
