02-20-2017, 08:14 PM   #1
K10D menu frozen
I purchased a used K10d, which I knew had some sort of freeze-up problem. It was very cheap and I thought maybe I could fix it by changing batteries or firmware. I was wrong. I inserted a new, newly-charged battery (not OEM, but 7.4v, 2300mAh, 17.0Wh). When I turned the camera on, it showed the "Date Adjust" screen, with the highlight on "Date Style". I have not been able to get any response out of the screen, although, with the ring around the 4-way controller set at "SEL" I can see and move the focus point dots in the viewfinder, so there is connectivity from the 4-way controller.
I also own a K100d, so I am not totally unfamiliar with the menu system used on the K10.
I tried to update the firmware to version 1.31, but no luck. I have not been able to move out of the "Date Adjust" screen, or get any response within that screen.
Any suggestions would be most appreciated. Thanks in advance.
02-20-2017, 08:38 PM   #2
Maybe just the directional buttons are broken? I seem to remember that the K10D family still used an older, flimsier design.
02-20-2017, 10:06 PM   #3
K10D menu frozen
Thanks Adam - Good point. The directional buttons on the 4-way controller ring seem to work, to an extent - at least they cause different AF points to light up in the viewfinder when I press them. But meanwhile, the Date Adjust screen is still displaying on the LCD monitor on the camera back and there is no action evident there. It would seem that the 4-way controller should be making different selections on the LCD Date Adjust screen while that is displayed, but instead it is highlighting different AF points in the viewfinder and no action on the LCD screen, so it seems that the 4-way buttons are not connected to the LCD menu screen.
I have not been able to close down the Date Adjust screen or change it in any way. The only things I have been able to do is to: (1) turn the camera on, which results only in the display of the Date Adjust screen, (2) highlight different AF points in the viewfinder (Date Adjust screen still displayed), or (3) turn the camera off.
02-21-2017, 03:32 AM - 1 Like   #4
Dartmoor Dave's Avatar
PK Tether might help. That way you can connect the K10D to a pc via usb and see if the camera is at least working well enough for PK Tether to detect it. If the camera is detected, you might be able to operate it remotely and maybe that will unstick the menu system. You can also use PK Tether to get into debug mode, which offers further options that might work.
02-21-2017, 06:13 AM   #5
photoptimist's Avatar
Strange! In theory, if the "Date Adjust" screen is up, then any presses of the 4-way controller should be interpreted by the software as commands to change the Date not to change the AF point. So it seems something is corrupted in the software that it's mis-interpreting the 4-way inputs.
A few suggestions in addition to Dartmoor Dave's good idea:
1. Try exercising the ring around the 4-way (putting it in Auto/SEL/center). Maybe if the ring is in AUTO, the 4-way commands will be sent to the LCD/menu subsystem.
2. Yank the battery while the camera is on and showing the "Date Adjust" screen.
3. Load an OLDER version of the firmware (then reinstall the newest).
4. Try to find the magic reset keypress maneuver for the K10D (if one exists). Most digital devices have some special keypress combination that does a full reset. It usually involves holding some combination or sequence of buttons for a very long time while turning the device on or off. I've never heard of one for Pentax cameras but I'd not be surprised if one exists.
Good luck!
02-21-2017, 06:22 AM   #6
Good luck!
How do youload the older firmware version ? because Pentax saids thats impossible & how would you get the older version anyway as they only ever have up the new version to load.
I hope you didnt pay too much as I think it might be money wasted IMHO
02-21-2017, 01:03 PM   #7
K10D menu frozen
Thanks to all for your helpful suggestions. I'll try them and let you all know what happens.
03-02-2017, 04:52 PM   #8
Update: I have tried the various suggestions above and unfortunately, the camera is still stuck on the date adjust screen. I tried PK Tether and found out by doing so that the camera did not recognize my Windows computer, nor did the computer recognize the camera. I know that my USB cord is good because I could use it to hook my K100D to my computer successfully. I learned that pressing the shutter button halfway, or pressing the info, or the display arrow button would wake the LCD monitor after the screen timed out.
I contacted the Ricoh live chat but did not find any magic bullets to help my situation there. I was told, when I asked about any special keystroke sequence, that I should try pressing menu, then the 4-way up twice, then right once, then up once, then press OK. That did nothing for me, but I mention it here in case it may help someone else at some time.
I think I will get inside the camera body and look to see if anything appears disconnected or otherwise wrong. I recall seeing a thread on the forum showing some photos of that process so I'll try it.
Thanks to everyone for your kind help.
03-02-2017, 08:32 PM   #9
sounds like some one had it apart and didn't plug in one of the ribbon cables properly. or cannibalized the camera for the back and put a defective on on that, and resold it.
03-03-2017, 05:34 PM   #10
Yeah, you are probably right. I've tried to find keystrokes for a hard reset, have tried the MODSET hacking routine, but the camera does not appear to either read the SD card reader, or recognize a USB connection. So I think something must be disconnected/missing. I'm just going to have to get up courage and get into the insides and see what I can find. I found a link that one of our members posted to the forum for the k10d service manual. That has detailed instructions and excellent photos of the insides being disassembled, so I'll give it a try.
03-03-2017, 08:25 PM   #11
QuoteOriginally posted by dappel Quote
if it doesn't read the sd card, you are flat out of luck.I PICKED UP ONE USED SAME MO,it turned out to be the motherboard and the sd card mount was severed. Not a fix able item. sound to me like some one had a go at trying to fix it already.
camera, controller, date adjust, firmware, frozen, k10d, k10d menu, menu, move, pentax help, photography, response, screen, troubleshooting
LCD screen frozen at menu screen - had to remove battery konquerian Pentax K-3 16 04-25-2014 02:53 AM
K10d - Menu Problems... mrchris Pentax DSLR Discussion 5 12-26-2009 02:52 PM
K10d-debug menu-IR possible? Bokeh Pentax DSLR Discussion 6 05-17-2008 05:54 PM
Menu Screen on K10D RussellW Pentax DSLR Discussion 12 02-04-2008 07:12 PM
K10D Menu Typos Faither Pentax DSLR Discussion 13 12-02-2006 10:28 PM
All times are GMT -7. The time now is 02:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
