03-06-2017, 07:53 AM   #1
K50 Changed battery whilst switched on - won't now switch on -
Grateful for some advice. Is it best to now leave battery in or remove it?
Tried the mains power adaptor but this does not work either.
---------- Post added 03-06-17 at 08:02 AM ----------
I just brushed the contacts and made sure battery was clean and it now works!
Instructions do say not to do this - but don't say what may happen if you do or how to fix it..........
Won't do this again.
03-06-2017, 08:33 AM   #2
UncleVanya's Avatar
Does it do anything or just act totally dead?
03-06-2017, 09:42 AM   #3
LoneWolf's Avatar
QuoteOriginally posted by Roger28 Quote
Did this myself with another Pentax model (a K5ll or maybe a K3 I think) and also a Canon compact. I got away with it with both cameras: probably because the camera, although on, was not actually doing anything at the time.
Although not a wonder cure, removing the existing battery and replacing it with same (if known to be fully charged) or your spare (again if known to be fully charged) can cure a number of different problems (e.g. mirror flopping for one). Brushing the contacts and making sure a battery is clean is however a good idea if a camera fails to activate and the battery is known to be fully charged, I think: belt and braces!
Glad you got away with it.
Cheers,
LoneWolf
03-07-2017, 08:47 AM   #4
Thanks all.
It just would not switch on.
But I would still like to know why this practice is a bad one, what damage can done and how it would be fixed - or is it always just a temporary problem?
03-07-2017, 11:22 AM   #5
UncleVanya's Avatar
Thanks all.
State of the current processing could be impacted. I imagine the main risk is a file getting damaged in mid-write. The lockup may always be temporary if that's the case. I just don't know and perhaps Pentax / Ricoh doesn't either.
battery, battery whilst, camera, k50 changed battery, pentax help, photography, troubleshooting
K50 won't change AF.C mode, bad focus on kit lenses Clary Troubleshooting and Beginner Help 12 06-24-2015 11:55 AM
Battery Life whilst using Remote Assist Dunc's Troubleshooting and Beginner Help 7 02-07-2013 07:36 AM
Battery won't switch.... slip Troubleshooting and Beginner Help 5 09-13-2011 06:01 PM
K10d battery empty over night - camera was switched off Noisychip Pentax DSLR Discussion 15 04-01-2008 01:06 PM
All times are GMT -7. The time now is 10:40 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
