The title has an
irrelevant error, but I mention it anyway since I can't change the title at this point:
The lens is a M39 silver (aluminium, LZOS, 1969) Jupiter-9 85mm f2.0.
With a M39 to M42 adaptor / thread added.
The lens is tested earlier with a K-30. And has worked perfect, as any
true M42, in
every sense.
Quote: Have you tried using your K-3 with other M42 lenses?
*** Just tried with a Meyer-Optik Görlitz Oreston 50mm f1.8 M42.
Both problems remain the same. During M-mode; (1) green button does not work in live view. (2) And in
info-view, still stuck on auto iso.
Quote: Auto-ISO is not available in M mode on the K-3, regardless of the lens mounted. Your observation concerns me.
Me too! In M mode and
info view the auto ISO is marked as default setting and can't be changed no matter what. I at least managed to get it to
auto ISO 100-125.
But, on the main LCD view (normal operation) I've been able to make it stick to the lower ISO 100 with the ISO button (but the default setting is still auto ISO 100-125).
Hope it makes sense.
Quote: I don't know what LCD-mode is, but in live view, the green button should still work regardless of whether the base is conductive. The EV scale on the rear LCD when used with lenses lacking the "A" contacts on the base is only active when setting exposure compensation.
Yes - live view.
The green button does not work in live view, during M mode.
Quote: The EV scale on the rear LCD when used with lenses lacking the "A" contacts on the base is only active when setting exposure compensation.
Thanks for the info.
Quote: Is it safe to assume that you can still manually set the shutter speeds using the e-dials?
Yes!
But without any EV scale indicating correct exposure. As you say, EV scale only for compensation.
And if I compensated low, the LCD gets dark as expected. Using the green button at that point reset exposure compensation to zero (0) and the screen brightens up again.
But of course, the shutter speed reamin the same.
Using the green button when the EV compensation bar
isn't present, and nothing happens. No change in shutter exposure / shutter speed.
Quote: My J-9 does not always show F--- for the aperture.
Mine neither. As goes for my Görlitz 50mm and my Tair-11a.
Quote: This may be a concern, but maybe not. The K-3 plays nice with non-conductive base lenses M42 lenses except for catch-in-focus.
Aperture on this K3, and my k30, has never been any concern. This Jupiter-9 is a pre-set lens. And my M-Görlitz 50mm has the pin modified.
(1) My issue is that the green button in M mode has no impact
shutter speed. Automatic metering in AV mode works fine.
(2) And that I can't change the auto ISO
default setting.
Thanks for the help!
