Originally posted by Sluggo Sorry, grog is right. What you describe is exactly how the MZ/ZX cameras behave when the gear on the mirror motor cracks. People sometimes assume it's an electrical problem because the battery drains so fast, but that's just an artifact of the motor getting stuck.
Just experienced this mirror up problem on my MZ-7.
Hence adding some extra info:
Symptoms:
- sounds like an extended exposure of many seconds, as mentioned higher.
- camera locks up (no reaction to any button, including on/off button)
- if you unmount lens, you can see the mirror is up
- batteries empty quickly, they even get warm, as some parts of camera. It seems the camera draws excessive power to keep mirror up frantically...
The last point is IMHO the reason why you should remove batteries as quick as possible. Overheating batteries and circuits can't be good.
Strange: the film advance picture number indicator keeps showing last number even when batteries removed, there seems to be some backup battery. Mirror keeps up, even after removing battery, might be because of backup battery.
Remedy, at least temporary:
Wait long enough without batteries in camera. Hour(s?), hard to say, didn’t wait next to camera.
Until LCDdisplay goes blank -no picture number- and mirror is down.
Re-insert batteries. Camera works again....
Just don’t know how many times I can repeat this trick... Time will tell.
But I have feeling that it is essential to remove batteries asap to avoid overheating and stressing the mechanism when it hangs...
