03-17-2017, 08:46 AM   #16
Robin CB's Avatar
A few more pics:
The M42 mount
03-17-2017, 09:00 AM - 1 Like   #17
Senior Moderator
BigMackCam's Avatar
QuoteOriginally posted by Robin CB Quote
A few more pics:
The M42 mount
OK, well, that is what's commonly-known as a "flanged" adapter. It's bringing the mounting point of the lens slightly forward of the camera's own mount, and slightly forward of the correct registration distance for an M42 lens. As a result, you lose the ability to focus the lens to infinity... though I'm a little surprised by just how much of a difference the flange is making with your lens.
The next thing I'd try would be a non-flanged adapter. This fits into the camera's own mount and stays flush with the mounting ring (see attached photo). The third party adapters vary hugely in quality, but even the cheapest work well enough...
03-17-2017, 09:01 AM - 1 Like   #18
boriscleto's Avatar
That is a non-infinity adapter.
This is an infinity adapter with an inner flange. But it costs several times what the lens would be worth...
CAMERA MITSUBA | Rakuten Global Market: Modern international M42 to PENTAX K Mount Adapter "instant delivery ~ 3 business days after shipping, black inner reflection to keep! Pentax screw mount lens can be attached to a K Mount body mount adapter
But if you were to invest in other lenses without the A/M switch it might be worth it...
03-17-2017, 09:02 AM   #19
Robin CB's Avatar
QuoteOriginally posted by ripper2860 Quote
The OP has not specified (or I overlooked), but the Zeiss could be a 2-ring preset with no aperture stop-down pin. Just checking to see if the adapter could come into play.
Thank you both.
I am trying to post pics of the lenses, but I must have run out of quota.
They both have a silver pin in the same location.
---------- Post added 03-17-17 at 09:06 AM ----------
Thanks - I will order one(although probably not the Pentax original - they seem a tad pricy in the UK)
03-17-2017, 05:36 PM - 2 Likes   #20
35mmfilmfan's Avatar
Robin,
I picked one up (genuine Pentax, second-hand) from my local dealer for a fiver - I can pop in there tomorrow and see if he has another, if you're interested.
Tony
03-19-2017, 12:54 AM   #21
Robin CB's Avatar
QuoteOriginally posted by 35mmfilmfan Quote
Robin,
Tony
That would be superb Tony.
Sorry I missed this earlier - if you could pop in when you are next going I will happily stump up a fiver (or up to a tenner) plus p&p.
I have a cheap Chinese version on order, but a real Pentax version would be a very nice to have.
Thanks,
Robin
03-19-2017, 01:15 AM   #22
Senior Moderator
BigMackCam's Avatar
The cheap versions are fine - I have a couple I use on occasion - but the genuine Pentax article is much nicer quality, and is a little easier to fit and remove
My favourite of the flush-fitting M42 adapters is from Kipon (available on Amazon UK here). It's not cheap, but it's very high quality and well-finished. The reviews suggest to me that it's misunderstood. It has an internal flange that some believe is supposed to keep the aperture pin pushed down on auto lenses. Perhaps that is the intended purpose, and if so, it doesn't work for all lenses as it doesn't push the pin in far enough. However, that internal flange also protects the camera's SDM contacts. I have a couple of lenses (one is a Jupiter-21M) where the aperture pin is rather long and not well rounded off, and it gouged a groove into the SDM contacts on my K-5 when fitting and removing the lens. Had I been using the Kipon adapter, that wouldn't have happened...
03-19-2017, 03:04 AM - 1 Like   #23
Robin CB's Avatar
Thanks Mike,
I have added that to my Amazon wish list. I will wait and see if Tony can help (and what the cheap Chinese version does) first though.
03-19-2017, 04:02 AM - 1 Like   #24
PM on its way.
adapter, apertures, camera, f2.8, focus, lens, lenses, m42, m42 lens, mount, pentax help, photography, pin, post, results, troubleshooting, zeiss
For Sale - Sold: 3rd Pty M42, Helios-40-2, 28, 35, 85, 135, 200 and 450mm, M42-EF & M42-Nikon MightyMike Sold Items 80 12-29-2017 02:58 PM
For Sale - Sold: 3rd Pty M42, 70-150mm, 135mm F2.8, 200mm F3.5 M42-K, M42-EF & M42-Nikon Adapters MightyMike Sold Items 72 12-26-2016 09:37 AM
Trouble Mounting an M42 lens via an M42-K Adapter onto K-mount Bodies fwcetus Pentax SLR Lens Discussion 9 09-19-2015 02:51 PM
Is this a front focusing camera problem or lens problem? Lens tests Metalwizards Pentax K-r 15 03-06-2011 01:24 AM
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 39 11-03-2010 06:02 PM
All times are GMT -7. The time now is 04:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
