03-11-2017, 04:13 PM   #1
Robin CB's Avatar
M42 Lens problem
Firstly - if this is in the wrong place, please move it :-) I couldn't work out a better sub-forum.
I have recently acquired (from difference sources) a couple of M42 lenses - A Carl Zeiss JENA Tessar 50mm F2.8 and a Kaligor 28mm F2.8.
Then I bought a cheap M42-PK adapter off that well known auction site and tried both out on my old K100.
The Zeiss seems to give reasonable results (see below for aprox 1/10 crop), but the Kaligor has trouble focusing. For a similar shot from the same position (about 6ft away from the bush) and with both on F2.8, I get very different results (again - below).
The Zeiss focus ring read where I would have expected, but I could only get the Kaligor to focus at all by setting it to infinity.
I know the lenses are very different, but I was expecting the focusing to be similar (given the same adapter was used).
Also - having tried different apertures, the Zeiss gives the expected focal length variation, but the Kaligor gives similar results at all apertures.
Is the Kaligor correctable / am I doing something wrong, or should I write it off (it was a give-away)?
Thanks,
Robin
Photos: Top - Zeiss, bottom - Kaligor. Shot on different days so the light was different (Zeiss was overcast and the Kakligor was sunny)
PENTAX K100D  Photo
PENTAX K100D  Photo
03-11-2017, 04:17 PM - 1 Like   #2
BigMackCam's Avatar
I could be wrong, but I suspect the Kaligor is a T-mount lens (also a 42mm thread, but with a slightly different pitch) which requires a T-mount to M42 (or T-mount to K) adapter. They're readily available...
03-11-2017, 04:44 PM   #3
Robin CB's Avatar
Thanks Mike,
The adaptor fits on both with no forcing at all (it is very smooth), so I think the pitch is the same.
How else would I tell the difference?
03-11-2017, 04:55 PM - 1 Like   #4
BigMackCam's Avatar
Depending on the tolerance of the threads on the M42 adapter and the T-mount lens, it's often possible to fit the two together - even though they're different mounts
With T-mount lenses, the adapter for a native camera mount was normally held in place by one-to-four screws. Look at the lens threads, or just above the threads, to see if there's any evidence of screw marks, perhaps...
03-11-2017, 05:02 PM   #5
Robin CB's Avatar
The mount is proud of the flat of the lens back by less than 1mm, and there are 2 tiny screws.
Looks like I will be hunting for a T-mount adaptor in the morning :-)
Thanks Mike
03-11-2017, 05:04 PM   #6
BigMackCam's Avatar
Sounds like that's the solution. You're welcome, Robin
03-11-2017, 05:05 PM - 1 Like   #7
ripper2860's Avatar
If the Kaligar 28 is anything like my Kaligar 35/3.5 preset lens, it is a T-mount and requires a T to M42 adapter. Without the T adapter the rear element is too close to the sensor and registration is off. This really makes it virtually impossible to focus.
03-11-2017, 05:11 PM - 1 Like   #8
Not a Number's Avatar
Some of the inexpensive M42 adapters and extension tubes thread pitch is somewhere in-between M42 and T-mount. I have a set of extension tubes that M42 and T-mount threads into them fine and dandy. However the tubes won't thread into the genuine Pentax adapter, bellows or bodies.
You could always try hand holding the lens unmounted and see how it focuses with some distance from the body. How thick is a typical T-adapter? 10-15mm I'd take a wild guess - to lazy to dig out an adapter and measure it.
03-12-2017, 01:03 AM   #9
Robin CB's Avatar
I have a T-mount adaptor on order now :-)
Not being familiar with this mount type, I was surprised how thick it is. That would explain the focus issue.
Just hope the lens is worth it.......
03-12-2017, 03:05 AM - 1 Like   #10
QuoteOriginally posted by Robin CB Quote
A T-adapter is nice to have. You can play around with telescope adapters or fun mirror telephoto lenses
03-17-2017, 07:53 AM   #11
Robin CB's Avatar
Update:
The T-mount adaptor has arrived, but it doesn't seem to fit (see below).
The mount screws almost half way and the thread binds. I don't want to force it. I get the same result on my Ziess.
The packaging of the adaptor says T2-PK, so is the T2 different to the T-Mount?
Thanks,
Robin
Apologies for poor phone pics:
The mount without the adaptor:
03-17-2017, 08:04 AM - 1 Like   #12
boriscleto's Avatar
That is not a T-mount lens...The mount clearly has an aperture stop down pin, so it is M42...
Does the lens have an A/M switch? If not it is Auto only and will not stop down unless the pin is pressed...Using a normal M42 adapter it will alway be wide open.
There are M42 adapters with an flange inside to press the pin down, or one can be made. You can also gimmick the pin to keep it pressed down...
03-17-2017, 08:09 AM - 1 Like   #13
ripper2860's Avatar
Yep. That's definitely a M42 mount. Do you have a picture of the M42 / PK adapter you are using? It may have a flange that prevents infinity focus.
03-17-2017, 08:11 AM - 1 Like   #14
boriscleto's Avatar
QuoteOriginally posted by ripper2860 Quote
From the description in the first post the Zeiss works fine, it stops down, and the other lens doesn't...
03-17-2017, 08:21 AM   #15
ripper2860's Avatar
QuoteOriginally posted by boriscleto Quote
The OP has not specified (or I overlooked), but the Zeiss could be a 2-ring preset with no aperture stop-down pin. Just checking to see if the adapter could come into play.
adapter, apertures, camera, f2.8, focus, lens, lenses, m42, m42 lens, mount, pentax help, photography, pin, post, results, troubleshooting, zeiss
For Sale - Sold: 3rd Pty M42, Helios-40-2, 28, 35, 85, 135, 200 and 450mm, M42-EF & M42-Nikon MightyMike Sold Items 80 12-29-2017 02:58 PM
For Sale - Sold: 3rd Pty M42, 70-150mm, 135mm F2.8, 200mm F3.5 M42-K, M42-EF & M42-Nikon Adapters MightyMike Sold Items 72 12-26-2016 09:37 AM
Trouble Mounting an M42 lens via an M42-K Adapter onto K-mount Bodies fwcetus Pentax SLR Lens Discussion 9 09-19-2015 02:51 PM
Is this a front focusing camera problem or lens problem? Lens tests Metalwizards Pentax K-r 15 03-06-2011 01:24 AM
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 39 11-03-2010 06:02 PM
All times are GMT -7. The time now is 07:47 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
