Originally posted by pschlute You will also get focus confirmation (green hexagon in the viewfinder) if you leave the camera set to autofocus with a non-autofocus lens.
You get focus confirm even when the AF switch is on the manual setting.
Originally posted by Paul Pheiffer A word of caution: not all manual lenses meter correctly on the smaller lens openings (using the green button to obtain a reading) - mine tends to underexpose.
The truth is that metering is fairly inconsistent for almost all lenses when using stop-down metering on modern dSLRs and can happen at both wide and narrow apertures. The causes are complex and related to the focus screens optimized for use on auto-focus cameras. The effect varies by both lens and aperture and is not easily countered by simply applying exposure compensation. Fortunately, current generation Pentax dSLRs behave much better than my K10D from 2007. That camera could vary as much as three stops over/under exposed between maximum and minimum aperture with some lenses.
Originally posted by Wheatfield This is probably because you are outside of the meter's range when trying to meter at small apertures.
This is a very important observation. The lower limit of meter sensitivity is very quickly reached when doing stop-down metering at even moderate apertures in dim light. As the meter loses sensitivity at lower light levels, underexposure is the result. The user manuals for legacy stop-down meter cameras such as the Pentax Spotmatic often came with a chart indicating the combination of shutter speeds and ASA/ISO that were outside the "coupling range". The Spotmatic goes so far as to have a red warning flag that displays when the combination of shutter speed and ASA/ISO is outside the meter's range. On that camera at ASA/ISO 100, the full range of apertures (f/1.4 - f/16) and shutter speeds (1s - 1/1000s) are available for metered exposure. At ASA/ISO 400, the lowest valid metered shutter speed increases to 1/4s. The meter needle will respond at lower speeds, but the reading will not be accurate.
The GPD and RGB meters on modern cameras are more sensitive, but the same concept applies. For example:
Stop-Down Meter Limit: Pentax K-70
(sensitivity 0 EV
100)
ISO | Max Exposure |
100 | 2s |
200 | 1s |
400 | 1/2s |
800 | 1/4s |
1600 | 1/8s |
3200 | 1/16s |
6400 | 1/32s |
(Calculated for f/1.4 from published meter sensitivity. Actual values may be different.)
