sorry to hear about your problem.
I usually use
Pandora recovery when all hopes are lose. If you want to try it out, It is free. Windows 10 might tell you that it is a non-certified software and ask if you want to run it. Never mind those message. I has been using this software since windows7 and it never add a spyware / adware on my machine.
- Insert SD card into your PC and Open Pandora recover after the installation, and it will scan your computer.
- When it done scanning, select “Lunch wizard…” under “Tools” menu tap up top and follow the guideline.
- Select “No, I did not find my files” and select Next.
- you should see your SD card listed in the select box. Select your SD card and click Next.
- Select “Browse: I want to browse the drive and review individual folder and files” (you can select another option too.) and click Next.
- When it done another scan. it will show you everything still on your SD card regardless of file being deleted, damaged or hidden. Select directory or files you want to recover and go to File > Recover to…
It is no guarantee you will be able to recover anything but I accidentally format one of my photo hard drive think that I had it backup in another physical drive just to find out a few week later I didn't. I use Pandora recovery and it found more than 80-85% of my photo.
Good luck.
