Originally posted by enyaw Hi are the images from a K50 at 3200 ISO acceptable? I know 1600 is ok, but I've read you can push the iso up to 3200. Does daytime differ from nighttime while using 3200. I intend to do some birding and will need fast shutter speeds with a slow lens f5.6.
thanks,
ie auto iso 100-3200, I previously had it at 1-1600. Just curious, before I actually go out and try it
You've had some great answers already, but I'll add one more...
I regularly shot my K-5 (and still do, sometimes) at ISO 3200, 6400 or even higher. In reasonably good lighting (typically when it's the lens aperture setting that demands using a higher ISO), you can expect good results at ISO 3200 and even higher. In darker situations, you'll notice the noise a lot more.
Firstly, try not to crop your photos. The more you crop, the more prominent the noise will seem for the same viewing size - so, try to get your subject framed accurately to begin with, and avoid cropping as much as possible.
Secondly, shoot RAW, and invest in good post-processing software if you don't have it already. I wrote an article last year on
Lightroom processing for Pentax Q images, where I took a photo shot at ISO 3200 with my original-version Pentax Q and cleaned it up in Lightroom. The end result might surprise you. If this is achievable with the Q's tiny sensor, there's no reason why you can't get considerably better results with the K-50 at the same ISO
