Originally posted by semaca I'm using a K-3 and 18-135 and I always had sharp images with this lens, but something is not right now.
The surprising part is that it used to be good. Sometimes a lens can have a problem, but its usually either already present when you get it, or it develops after some shock (bumpy travel, a fall, ...)
How does the focus ring turn if you switch to Manual focus? Does it turn smoothly, or are there odd resistances at some points?
You can search the forums or on blogs about how to use the focus fine adjustment correctly. Often people use some sort of focusing chart.
If adjusting for backfocus doesn't work, then the lens might have some other problem. Ideally you would test this lens on some other camera, just to pinpoint the issue. Is the lens still in warranty? I recommend you write a report about your experience to the repair shop
