Originally posted by ritualnet but it seems... difficult to manually focus without say a split circle to use to focus with, and no focus peaking either to help out.
I might be mistaken but there should be a focus indicator of some sorts in the K-5 (blinking sign in the viewfinder and maybe an accoustic sound - depending on your camera settings) if you half press the shutter button or the AF button on the back (again depending on your settings) while focusing the lens manually. It only works for the centre AF point with manuall focus lenses but that shouldn't be a big issue.
But even without focus indicator should normal and telephoto lenses be fairly easy to focus by sight allone. Wide-angle lenses are more tricky in that department.
