04-15-2017, 01:19 PM   #1
Problem with K-x camera
Hello everybody!
Today I have acquired used K-x camera. I have not previous expirience with any Pentax cameras, so I have one little question
I have - K-x with a last firmware from pentax site, 2 sets of fresh and good accu, 3 different SD cards (10 class), default settings, Auto pict mode.
If I shoot in ordinary environment - all working good. If I try to make photo with a bright (sunny day weather) light or with lack of light (under my table ) a problem is arised. Camera aquire focus, show correct values at indicator in the viewfinder, and ready to go. Next I completely press shutter button and hear sound of mirror, after it camera waits around 5-15 seconds (indicator shaded, values of ISO, shutter speed etc. blinking and changing), and then I hear shutter sound. Image does not write.
Is it camera problem? Or may be I miss any settings?
With best regards,
Vasily
04-15-2017, 01:26 PM   #2
SpecialK's Avatar
Try using a couple different modes, such as P and Av, etc. If those do not work correctly I suggest going into the menu and do a factory "reset".
04-15-2017, 01:49 PM   #3
Would be a good idea to try exposing M mode to check to see if the camera can shoot correctly in those conditions.
04-15-2017, 01:53 PM   #4
Factory reset did not help. Problem exist in all modes except LV.
04-15-2017, 01:55 PM   #5
In M mode I have this problem too
04-15-2017, 03:28 PM   #6
Is the drive mode set to 12 second time delay (AKA self timer)? That would explain the delay between the mirror sound and shutter sound, but not the failure to write an image.
04-16-2017, 12:06 AM   #7
QuoteOriginally posted by Cthulhugan Quote
Drive mode is set to 12s. But delay from 5 to 15 seconds.
04-16-2017, 04:14 AM   #8
CLG
I have a k-x and have never heard of that problem. Just to clarify, do you want it to have a delay or not?
04-16-2017, 01:33 PM   #9
QuoteOriginally posted by CLG Quote
Of course no. I dont want to have this delay I think this delay is not normal for camera. Just like to know is it hardware problem, or software/settings issue.
04-16-2017, 03:44 PM   #10
Hello
Please check if your setting for the “drive mode” is “Drive Mode Single Frame Shooting” (first option from the left) – you access this option by pushing the “circular” button above the “OK” button and then you get a menu where you have five main options.
If you have not this setting as described – per your description it looks that you have active the third option “Drive Mode Self-timer (12 sec.)” instead, thus getting 12 seconds between activating the shooter button and the camera actually taking the shot -, you have to change the setting to the one described above to get the camera shooting immediately after pressing the shooting button.
Best regards,
04-17-2017, 12:48 PM   #11
Would like to say "thank you" to all who posts the answers! You have showed me the right direction
I have check all modes and settings, and remarked one thing - aperture did not changed in any modes and environments. I have checked it, and saw - arm (on camera body) which changes aperture on the lenses did not moved.
Some googling and I have got a video with exactly same problem on K50/K30
Now my camera fixed and working in all modes
camera, indicator, k-x, light, pentax, pentax help, photography, settings, shutter, sound, troubleshooting, values
Misc Energy problem? What energy problem? normhead Post Your Photos! 4 03-27-2014 05:00 AM
Camera? What camera? We don't need no stinking CAMERA!! RioRico Photographic Technique 2 05-17-2012 04:48 AM
Is this a front focusing camera problem or lens problem? Lens tests Metalwizards Pentax K-r 15 03-06-2011 01:24 AM
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 39 11-03-2010 06:02 PM
Card read problem K20d. Have you had this problem? rsi1986 Pentax DSLR Discussion 8 12-27-2008 05:25 AM
All times are GMT -7. The time now is 10:27 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
