Originally posted by Adam Tungsten lighting and a shutter speed >= 1/50s?
Adam, you are brilliant, thanks. I've never even considered that you have to keep shutter speed below a lights flicker rate. It was florescent lighting, and looking around the net, I see this exact effect. The different color and intensity tones in the same frame is a result I guess of the rolling shutter? I've never had this happen at the same location with my STakumar 50mm 1.4 and was dismayed that my new lens might have issues. This has turned to fascination.
Originally posted by DeadJohn Was the effect visible in the viewfinder or only in photos?
Any filter on the lens?
---------- Post added 04-16-17 at 05:09 PM ----------
I wondered about that, but do flickering lights only affect OOF areas?
No filter, and wasn't visible through the viewfinder. My guess is that the moons aligned and I just happened to catch the flicker in the oof at the right time.
Thanks guys!
Addendum: I'm reading that a few newer cameras have a flicker mode; do any Pentax bodies have this? It syncs the shutter release to correspond with the brightest point in the cycle. Neat stuff.
