04-27-2017, 04:11 PM   #1
Manual 15mm lens and shutter speed
Setting focus to manual and setting exposure dial to M,when shooting with a manual lens I set the aperture on the lens and set the shutter speed with the camera. When pressing the shutter release (K-1), the camera changes the shutter speed even though the shutter is set to manual. Why? Seems the camera should leave the shutter speed to what I set. In case it matters, the lens is a Laowa Venus 15mm macro.
04-27-2017, 04:33 PM   #2
enoeske's Avatar
QuoteOriginally posted by duogl Quote
2 questions? Do you have the custom option 4 set to on? Are you trying to use a P-TTL flash?
04-27-2017, 07:44 PM   #3
The lens appears not to have an "A" Automatic setting (or you are not using it.) In this case the lens is being treated as a fully manual lens and as you press the shutter button, the camera is metering and setting an appropriate shutter speed for you.
Enable the "use lens without A" setting and press the green button before taking a photo. The camera will then meter the scene and obtain a matching shutter speed for your selected aperture.
Regards
Chris
04-28-2017, 12:47 AM   #4
pschlute's Avatar
QuoteOriginally posted by seventhdr Quote
The lens appears to have no aperture coupling at all, so any change will result in the aperture opening or closing ....a bit like using a screw-mount Takumar lens. In that case the OP is better off using Av mode where the camera will set a shutter speed for him.
In Manual exposure mode the shutter speed should not change unless the green button is pressed; or the camera has a flash mounted that is not set to HSS and a selected speed above 1/200; or perhaps auto-bracket was selected
04-28-2017, 05:33 PM   #5
QuoteOriginally posted by enoeske Quote
Have it enabled and will try tomorrow. No flash.
Thanks for the quick reply
---------- Post added 04-28-17 at 05:43 PM ----------
Regards
Chris
Lens is completely manual. I've selected Under Custom, item 26 ' Using Aperture Ring
' I've set the choice to Enable".
Is that the same as "Use lens without A"?
It has an aperture ring but no "A" setting.
And thanks for the tip.
04-29-2017, 10:32 AM   #6
pschlute's Avatar
Yes that is the same setting.
On a lens that will stop down physically when you turn the aperture ring, you can use M or Av for exposure. Best procedure is to focus while the lens is wide open (so you can see clearly !), then stop down for capture.
15mm, 15mm lens, 24x36mm, aperture, button, camera, custom, flash, full-frame, lens, lens and shutter, pentax, pentax help, photography, press, shutter, thanks, troubleshooting
Shutter failing, over exposing during high speed bursts on K5IIs in Manual Tighelander Troubleshooting and Beginner Help 3 04-04-2016 12:49 PM
MX shutter sticking/locking over 1/60 shutter speed NitroDC Film SLRs and Compact Film Cameras 4 01-10-2016 03:53 PM
Shutter speed & aperture lock in manual mode - k-50 abhisna Troubleshooting and Beginner Help 2 08-15-2015 08:36 PM
Video mode and manual shutter speed/ISO ? alamm001 Pentax K-01 10 12-12-2012 04:49 AM
K10D and Green Button Manual Lens Shutter Speed David Pentax DSLR Discussion 4 10-15-2007 12:41 AM
All times are GMT -7. The time now is 07:38 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
