Originally posted by kamicota HERE is what we just bought
Congratulations Colin. This is the model I have too. It's great value.
If it doesn't come with a hood (and the ad suggests it doesn't) lash out and spend $2.50 on one, like this:
1pc Replacement Lens Hood For Pentax PH-RBG RBG 58MM DA 55-300 f/4-5.8 NEW | eBay Originally posted by kamicota NOW we have to find a CHEAP earlier Pentax K camera to Join the K-30 in partnership with the 55-300mm & or the 18-55mm Lens. Suggestions are truly welcomed OK!!! As I want to use one lens solely with one camera and the other also
Regarding the camera body, there are two schools of thought. (1) Get the same model you have, because you can operate it without thinking about it. (2) Get a model that gives you something that your K-30 doesn't.
I've tried both strategies. I had two K-30 bodies, and now I've got a K-3 and a K-S2. The latter strategy suits me now. The K-3 is an all-round better camera, but the K-S2 is great when I want to travel lighter, or I want wifi or the flippy screen. When I carry both, I usually put a telephoto lens on the K-3 (better AF, better metering, faster frame rate, the extra heft balances the lens better, a little more scope for cropping) and a wide angle or macro on the K-S2. Either camera is better than the K-30 (except the K-S2's ergonomics, and lack of wireless flash control), but the improved AF on the K-3 makes a big difference with a lens like the 55-300.
If you can run to a K-3 you won't look back. If not, consider one of the K-5 series - ideally the K-5iis because it doesn't have an AA filter. The flagship models offer many small advantages that add up to a lot - e.g. better battery, top LCD, more buttons, better dust control. more robust construction.
But if they are out of range, aim for the most recent model within your budget. The K-50 and K-30 are cheap now - albeit with the risk of aperture block failure. I'd look through the PF marketplace first.
