Originally posted by wlc1967 Unable to open DNG files recently purchased K-3 using CS3 or Gimp 2.8. I can read them in the camera and Jpegs open fine. Any suggestion?
Gimp doesn't read raw files. You'd need something like ufraw or better yet Rawtherapee. CS3 ACR maybe using DNG 1.0 or 1.1. Pentax DNG is V1.2 I believe. Current spec is v1.4. from October 2012. Any raw convertor/reader using the newer standard can read older versions. The opposite is not true.
If you still want to use DNG and CS3 as your editor then I recommend buying Lightroom as it will provide you with the conversion like ACR but work with CS.
If you want to still use Gimp then I recommend you download a current copy of Rawtherapee. My comparison findings against commercial products with the K3 are that it can more than hold its own. And I do find it better than ACR for the K3. Much better demosaicing with the AMAZE option than ACR.
