05-22-2017, 07:57 AM   #1
Pentax Me Super lightmeter not accurate!
Hey there, i'm new to this forum.
Yesterday i've bought a Me super, after i fixed the stuck shutter i saw that the lightmeter display inside the viewfinder is not accurate.
While the camera seems to choose the right settings anyway it shows wrong shutter speeds.
E.g.
Inside, camera set to iso100, lens to 3,5.
The camera will now show me something between 1/500 and1/1000
But when i press the shutter it sounds light something around 1/20
I did check if the scale was in the right position by turning on M mode and checking if the led was in the roght position. And it is.
Can i fix this somehow?
Thank you very much!
Daniel Melzer
05-22-2017, 02:45 PM   #2
Giveaway winner!
MysteryOnion's Avatar
Is the highest ASA setting and lowest ASA setting the same amount off...about 4 stops off?
If you aim at a steady light source, set to Manual and move the ASA from 12 to 1600, does the LED indicator go off the scale to top or bottom most or does it sort of repeat inself?
05-22-2017, 08:08 PM   #3
The mirror flip-up takes just as long for fast shutter speeds as for slow ones. Listening isn't an especially accurate way of judge shutter speeds.
Another PFer, taught me something useful.
-- Put an electronic flash on the camera, and aim the camera (without lens) toward a light-colored wall.
-- Position your eye behind the shutter opening with the back of the camera open.
-- Beginning with the flash-Sync speed (on my ME Super SE it's 1/125) and fire the shutter. If that speed is accurate the entire frame rectangle will illuminate.
-- With the ME, of course you have to use Manual mode to continue, which will involve trying each of the faster speeds in order. If each one is faster than the one before, a slightly smaller rectangle of light will appear when the shutter and flash fire.
I thought the speeds sounded way off on my Asahi Pentax ESII, but when I tried this test, I found the actually shutter open times progressed just as they should. I did have to test between some speeds more than once to be sure, especially as they got faster, but after that I was certain. This test doesn't give actual shutter speeds, but gives a good sense of relative speeds beginning with how the flash sync speed should function if it is accurate. My the first test roll of film confirmed the speeds were all reasonably accurate.
The test of you camera, of course, might confirm your suspicions, but more accurately than listening alone.
QuoteOriginally posted by Daniel Melzer Quote
E.g.
Daniel Melzer
camera, lightmeter, pentax help, photography, position, shutter, troubleshooting
Pentax D FA 150-450 focal length not accurate. JML69 Repairs and Warranty Service 3 04-19-2017 04:40 AM
Count not accurate mattieyp3 Pentax K-3 & K-3 II 6 03-02-2017 09:05 AM
Focus peaking not accurate audiobomber Pentax K-01 81 04-28-2013 12:49 AM
6x7 lightmeter not working smurley Pentax Medium Format 7 03-26-2012 04:53 PM
For Sale - Sold: Lenses: Sigma, Zenitar, Takumar; ME Super w/ winder; Weston lightmeter pbo Sold Items 13 07-16-2009 07:06 PM
All times are GMT -7. The time now is 09:00 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
