Originally posted by timw4mail fit snugly in the k-mount
A snug fit is the opposite of good fit. The genuine adapter is a loose fit by design. The intent is that the adapter will "snug" into the spring-loaded tangs on the body as the lens flange engages the body flange. This feature ensures proper registration distance for all lenses.
Originally posted by timw4mail There should probably be a list of decent knockoff adapters...
That would be nice, but even well-known brand names such as "Bower" are often sourced from multiple manufacturers and suffer from variable quality. I had a Bower stuck on one of my film cameras. It took several hours of effort before it could be removed, even using the provided tool.
Originally posted by Supakatti And the adapters, as far they are identical with original Pentax labelled, are safe to use.
I have yet to find one that is identical, though some are close. Most differ in tang size, tang ramp (fit way too tight), retension spring design, and/or machining of the tang ends. The last two characteristics have been implicated in the "stuck adapter syndrome", with the use of chamfered ends on all tang ends being the most likely culprit.
