Yes, it's a knock off of the genuine Miinolta P adapter down to the non-standard location of the notch and the holes and slots for the removal tool.
Here's the backside of the OEM Minolta P-adapter. Notice the holes and slots for the removal tool.
Here is a Minolta to M42 adapter I bought from Fotodiox - no markings whatsoever.
Here is a OEM Minolta Leica (m39) adapter. Note the position of the lock notch and notches for the removal tool. It has holes on the front for the tool but they don't go through as with the P adapter. Tool pictured following.
Below are the mounts for a Kiron 80-200 f/4 (for Minolta), Minolta MD 50mm f/1.4 and MC Rokkor-PF 58mm f/1.4 lenses. Note the location of the lock notch on all of them.
Typically if the notch is located in the center it is a Konica AR lens. On the far side (going clockwise) as pictured above for Minolta and on the near side it's for Mamiya EF. Just goes to show there are exceptions to rules.
