Originally posted by enyaw Hi, I'm debating if I should start to use shake reduction on my K50. I don't know under what condtions I would need it though and what lens it would help me with. Sports? Birds?
thanks.
Low shutter speeds with prime lenses < 200mm, under situations where the use of a tripod is either difficult or not permitted (it will of course work with longer lenses, but there comes a point beyond which in-lens stabilisation - if and where available - is said to be a more optimal solution).
It sometimes does not cope well with panning, it is worse than useless on tripods, and it is pointless at the sorts of high shutter speeds that are usually utilised to freeze action in sports.
The nature of my photography is generally such that I leave mine switched on constantly. Among other things, if you have a manual focus lens of A vintage or older fitted, this is the only way to ensure that the focal length is written to EXIF. The real decision is not when to switch it ON but when to switch it OFF.
