06-10-2017, 02:07 AM   #1
K1 camera wifi problem
I tried using the wifi with image synch on my mobile to take pictures remotely and every so often the camera wifi went off and had to go back and switch it on again from the camera. Is there some time limit how long it remains on? Couldn't find anything on the manual.
06-10-2017, 03:18 AM - 1 Like   #2
QuoteOriginally posted by jdou Quote
I don't believe there's a setting specific to the wi-fi, but there is a auto power-off setting in the camera itself. I'd increase that if needed.
06-10-2017, 04:06 AM   #3
I doubt whether that it the issue since once it went off while I was taking photos! Could other wifi networks in the proximity have an impact on it?
06-10-2017, 05:28 AM   #4
Yes other networks or network cards can interfere. I notice it on shoots near houses. It can be annoying at times.
06-10-2017, 05:28 AM   #5
Wheatfield's Avatar
I've had my WiFi switch off if my tablet decides it wants to switch to a different network.
06-10-2017, 05:36 AM - 2 Likes   #6
monochrome's Avatar
On your phone, turn off 'Ask to Join Networks'. Your phone will stop seeking and responding to the presence of another SSID Broadcast.
06-10-2017, 06:21 AM   #7
In fact I've noticed that sometimes it just stops responding no matter how much you touch the phone. I will try out your solution once again.
01-27-2019, 08:52 AM   #8
Hello there
I have the same problem with my
WiFi on my k1
I can take a few pics with image sync and the it drops the WiFi connection tho it says it is still connected in the iPad WiFi settings
Seems like it’s defo a camera fault as I have to turn the camera off to turn the WiFi back on!
If I try to reset WiFi or turn it off in the menu I get a screen saying “processing data”
Did you sort out the problem on yours?
I don’t know if it’s because of the new firmware I installed last week!!
01-27-2019, 10:15 AM   #9
amoringello's Avatar
Ditto on configuring your device (phone, PC, etc...) to not ask to join other networks. You might go as far as to ask it to forget all other networks that might have previously connected in the area.
But do allow it to remember your K1's network so it will auto connect, should it get disrupted for some reason.
It should remain connected, and when communication is frequent, the camera may not even go to sleep. My auto file transfer program pings the camera every few seconds to see if new images are available, and the camera never sleeps on its own over the course of multi-hour shooting events.
01-29-2019, 01:19 AM   #10
Hello,
I have checked all that! The strange thing is that the iPad show’s it’s still connected to the pentax in WiFi setting’s but the app says there is no connection and to reconnect I have to turn off the camera.
If I go into settings and try and manually turn off WiFi it says processing data!!
It’s strange it starts ok then quits after around 5 to 10 shots!
Does anyone know If there is customer support at Pentax where I can talk to a technician ?
Did have a quick look on there site but couldn’t see any link ?
02-11-2019, 07:53 AM   #11
I have the same problems.
camera, k1, k1 camera wifi, pentax help, photography, troubleshooting, wifi
Pentax K1 WiFi??? englishphotographer Pentax K-1 16 06-20-2018 06:23 PM
Would there by any demand for this WIFI product for the K1? peterh337 Pentax K-1 30 12-09-2016 08:08 AM
DXO Digital Camera with Wifi reivax Non-Pentax Cameras: Canon, Nikon, etc. 2 09-18-2016 05:54 PM
K-S2 wifi vs K-1 wifi robtcorl Pentax K-S1 & K-S2 7 04-03-2016 09:54 AM
K-S2 wifi problem. Bringass Pentax K-S1 & K-S2 5 10-16-2015 01:30 PM
All times are GMT -7. The time now is 01:54 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
