Originally posted by john e Found some reference to Ricoh having a P function. But the pin to activate will not match Pentax bodies?
Anyway the fellow I bought it from has used it on his K-1 in full manual/ I will also. Great lens.
Thanks.
Danger Will Robinson!!!
The "P" means Ricoh P mount, a variant of Pentax K. The pin you mentioned (the dreaded "Ricoh Pin") is a potential hazard when mounted to an auto-focus Pentax body. The AF drive well is in the path of the pin and if the two foul, the lens will be very difficult to remove!!!*
The threat is real and worth paying attention to. Here are the summary points:
- There are several versions of the Ricoh Pin ranging from a spring-loaded square-ended affair to an almost-flush ball contact
- The spring-loaded version is deadly and at very least will require considerable time with a thin feeler-gauge slipped between mount faces in an attempt to coax the pin to retract
- The ball type is fairly benign, but may still get caught in the AF pawl. If one wishes to take the risk with that type, take care to retract the pawl first by putting the camera in manual focus mode
- The pin may be surgically neutralized by simple removal (requires JIS screwdriver)
Just thought I would let you know.
* Worst case reports on the Web required application of a Dremel tool to cut the lens away. Not pretty.
