06-21-2017, 07:07 PM   #1
K3 ll GPS location limits
I have used the K3 ll GPS function to reduce star trails during lengthy night time exposures but am wondering if after you go through the process with the camera to activate the GPS location function if you are limited to that exact spot where your camera and tripod sit or whether it can be picked up and moved 10 feet or 50 feet? Any ideas?
Thanks, Bob
06-21-2017, 07:54 PM - 2 Likes   #2
photoptimist's Avatar
The answer would depend on the local variability of the magnetic environment (that's what's being calibrated during the setup process).
GPS, itself, is robust to any movement because the camera will just get another GPS fix to get the latitude and longitude wherever you go.
And the internal accelerometer of the camera will give an accurate estimate of how far above the horizon you are pointing and the roll angle orientation of the camera (i.e., whether it's in portrait, landscape, or some other orientation). That's also robust.
What is harder for the camera to know is whether you are pointing north, south, east, or west. That requires good magnetic compass data which can be tricky to measure because so many things can perturb the earth's weak magnetic field.
Thus the answer to your question is "it depends". If you are in the middle of an undeveloped rural field with no iron-bearing minerals deposits, you could probably move a mile with no problem. But if you are near buildings, cars, power lines, buried pipes, iron-bearing rocks, volcanic deposits, etc, then maybe 10 feet might throw things off.
06-21-2017, 10:41 PM - 1 Like   #3
QuoteOriginally posted by woodywesty Quote
Thanks, Bob
A small movement shouldn't make a big difference, IMO. However, if you ever start getting poor results, I'd just re-calibrate and you should be all set.
06-22-2017, 05:15 AM   #4
Thanks Photoptimist and Adam, You have answered my question. I am taking another "night sky" photo workshop and once before used the GPS to allow for longer exposures than others could take without star trails and it is great, but... it is a little putzy having to go through the setup process each time you change your position. We are in northern Minnesota on the Canadian border with lots of crazy magnetic variations so it looks like if I move then I re-set the GPS. I can live with it ;-) It is simply amazing what the sensor can pick up that our eyes can't see... ;-)
Cheers, Bob
camera, feet, function, gps, k3, k3 ll gps, ll gps location, location, pentax help, photography, troubleshooting
K3-ll with Sigma 70-200mmF2.8 ll macro Trouble Craig66 Pentax K-3 12 10-10-2015 08:00 PM
Landscape Location, Location Bob Harris Post Your Photos! 17 10-26-2013 09:16 PM
Light, Location, Location & Opportunity interested_observer Photographic Technique 2 01-03-2013 12:03 AM
Location, Location, Location... bluespearbone Digital Processing, Software, and Printing 13 02-16-2008 06:57 PM
Picture/pixel location to sensor location mapping eman Pentax DSLR Discussion 5 08-06-2007 10:03 PM
All times are GMT -7. The time now is 12:17 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
