06-22-2017, 02:07 PM   #1
davedyer's Avatar
T mount problem
I asked this question in the Astrophotography social group and received a few answers but I thought asking in a wider venue might help me further. I am a new owner of a K-70 and purchased a Pentax K SLR / DSLR Deluxe Astrophotography Kit (1.25") from Telescopeadapters.com and it's a very nice kit. However, the t-ring (made by Bower) does not fit flush with the camera body and the lens information contacts are exposed to the dust and bugs and dew. I used the t-ring the other night for some prime focus activity and the next day I had trouble with auto-focus. After cleaning the contacts 3 times with a microfiber cloth the camera worked fine again. Someone at the aforementioned astrophotography suggested buying some o-rings to fill the gap, and I could do that, but I think it would be better to find a t-ring that fits properly, one that doesn't leave the contacts exposed. Any ideas? Thanks
-dave
IPhone 6s Plus  Photo
06-22-2017, 04:19 PM - 1 Like   #2
QuoteOriginally posted by davedyer Quote
Simply put, there should be no gap.
Check for marks which might indicate that it is binding, something's wrong.
06-22-2017, 05:26 PM   #3
SKYGZR's Avatar
Location: Milky Way Galaxy, Planet Earth, Speeding towards the Virgo Supercluster
You will probably not find any other to completley seal off the contacts. Your only solution will be to perhaps use some electrical tape wrapped around it to help seal it. (Wrap the tape around it after installing.)
I can check mine (I have a few different kinds), to see if any completely cover the contacts, yet I have had no problems if they don't.
06-22-2017, 05:33 PM   #4
A rubber band or one of those elastic things people with hair use to hold it back might work to protect the contacts when you're using the t-mount. Then just pop it off when you use a regular lens.
- Eric
06-22-2017, 08:31 PM   #5
Not a Number's Avatar
I have one of these. Very good quality. It covers the contacts on my K10D.
Qualide T-Mount Lens Adapter for Pentax K 35mm SLR Film Camera 25-166-2227
The rubber band/o-ring/hair band is a common solution for screw-mount lenses with narrow bases that do not cover the contacts.
06-24-2017, 06:25 PM - 1 Like   #6
davedyer's Avatar
t mount problem solved!!!
I spoke with a young lady at Bower over the electrical telephone and she suggested that the ring I had was either a clone or outdated. I ordered one from B&H (it looked a bit different with knurls on the outer edge) and it arrived today. And it fits like a glove; no more gap, no more exposed contacts.
camera, contacts, kit, pentax help, photography, t-ring, troubleshooting
K-3 Lens Mount problem - loose wire behind the mount stefantuchila Troubleshooting and Beginner Help 3 10-16-2016 01:11 PM
Grooved tube inside rear mount on Pentax 300mm f/4 rattles, is this a problem? gazelle01 Repairs and Warranty Service 11 04-04-2016 12:36 PM
K-Mount or A-Mount to E-Mount Adapters with AF? reivax Non-Pentax Cameras: Canon, Nikon, etc. 5 01-01-2015 09:35 AM
K-5 battery problem? camera problem? user problem? imtheguy Pentax K-5 39 11-03-2010 06:02 PM
All times are GMT -7. The time now is 11:41 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
