Originally posted by jlstrawman Press the LV (Live View) button first, then the "up directional button".
Yes, ta for pointing that one out, I'd not used that approach before.
Originally posted by cpoteet Now: how oh how, or where oh where did you find that little jewel of a tip? Sounds to me as if the owner's manual has an opportunity for some editing on the topic.
Above the up direction button on the 4 way controller is the 'Change AF Point/Card slot switch button' (you can read about it on page 9 of the manual). I just press this button to cycle between adjusting AF points and accessing the drive mode menu. When it's not set for AF point adjustment the up controller accesses the drive modes with a single press. Try pressing the 'Change AF Point/Card slot switch button' on it's own and see if the 4 way controller changes from AF point adjustment to drive mode/WB/Custom image settings/screen brightness etc.
Tas
