04-30-2018, 11:41 AM   #31
acoufap's Avatar
Since the focal length is there, I would say your mac software is simply failing to recognize the lens id. It's up to the program viewing the image (not the camera) to figure out what the lens is.
If you attach a photo straight out of camera (without editing it), you should be able to see the lens name. You can also do so by uploading here:
Check Camera Shutter Count and Manufacture Date
I also own the DA55-300PLM and work on Mac 10.11.6 - never use Apple Photos (Version 1.5) but tried it with one of my dng files for this case. Using the export function all metadata information is embedded in the jpg file. So IMO Photos (at least my version - german) or the lens ID is not the problem. The metadata of the jpg file can be viewed using Apple Preview.
04-30-2018, 12:41 PM   #32
Otis Memorial Pentaxian
QuoteOriginally posted by acoufap Quote
This user is using Photos 3.0 (presumably on High Sierra) and while there is a chance that it copies only limited metadata on export, it is also possible that there may be other tools that may be at fault further upstream. @CooperPete , what is your process from camera to sharing the images here?
04-30-2018, 09:33 PM   #33
Hi, All:
I check my photo use the link Adam suggested, "check the camera shutter count and manufacture date", all info including lens info is listed (see screen shot photo). My mac is "macOS High Sierra Version 10.13.4, The fact is, all my other lenses including old Zeiss 135mm and Pentax M lenses registered and showed on my Mac Photo app. as much as i like this lens, I think I am going to give it up. I just bought the HD Pentax DA 55-300mm f4-5.8 ED WR, it does have aperture ring, which i liked. Thanks to all for your generous Help. i learned quite bit. will report back.
04-30-2018, 09:34 PM   #34
04-30-2018, 10:09 PM   #35
QuoteOriginally posted by CooperPete Quote
Hi, All:
So, as suspected, the problem is with the photo viewer on your mac, and not with the lens. You should see if there are any updates for the software, or use a different program to extract metadata (I would recommend Adobe Bridge CC, it's completely free).
AFAIK the F4-5.8 lens doesn't have an aperture ring But it is quite a bit older, so its name should be recognized in your existing software if you decide to go down that route.
05-01-2018, 12:05 AM   #36
microlight's Avatar
I have both the PLM and the original non-WR 55-300; neither has an aperture ring, and thereís no way Iíd give up the PLM! There seems to be no need to worry about going through a process to wake it up; with mine, if you turn the camera on before extending the lens, you get a warning message on the back screen which goes away when you unlock and extend to 55mm, and then it operates normally.
I second Adamís suggestion of using the free Adobe Bridge for routinely viewing the EXIF data, although off the top of my head, I donít think that it gives shutter count (not currently at my computer.)
05-01-2018, 08:50 AM   #37
Larrymc's Avatar
Hi, All:
I think you are mistaking the focus ring for an aperture ring. The focus ring is where the aperture ring is on some lens. The lens has "quick shift which" allows you to manually focus the lens easily. The aperture is electronically controlled.
Larry
05-01-2018, 01:15 PM   #38
U are right, i am completely new to the DSLR world, I probably did confused these two, It is the focus ring im talking about. I am so thankful to all your kind help.
Thanks to all.
af, camera, f4.5-6.3 ed plm, focus, hd pentax-da 55-300mm, kp, kp and hd, lens, pentax help, photography, plm, plm wr, trouble with kp, troubleshooting
Pentax HD PENTAX-DA 55-300mm f/4.5-6.3 ED PLM WR RE Lens $402! Spodeworld Pentax Price Watch 6 06-09-2017 09:09 AM
The new HD DA 55-300mm F4.5-6.3 ED PLM WR RE and focus breathing concerns anu l Pentax SLR Lens Discussion 3 12-09-2016 08:19 AM
HD Pentax-DA 55-300MM F4.5-6.3 ED PLM WR RE for 306 EUR beholder3 Pentax Price Watch 3 11-18-2016 05:08 AM
HD Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE - No reviews whyhaveone Pentax SLR Lens Discussion 9 11-03-2016 02:36 AM
HD Pentax-DA 55-300mm F4.5-6.3 ED PLM WR RE Announced PF Staff Pentax News and Rumors 4 06-09-2016 03:45 AM
All times are GMT -7. The time now is 06:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
