07-09-2017, 07:35 PM   #16
QuoteOriginally posted by davidreilly3207 Quote
If I understand correctly, you are concerned that you will lose the rubber plug that covers the contacts on the camera when it is stored in the grip but the grip is not attached to the camera due to the plug fitting loosely in the storage slot of the grip. I don't understand your concern since you should be placing the plug in the camera as soon as you remove the grip. It can't fall out when the grip is attached as it is sandwiched between the camera and the grip.
BTW, I rarely remove the grip on my K-3. I set the battery in the grip as primary and swap with a spare & charge it. The battery in the camera rarely needs charging although I do swap it occasionally to even out usage on the batteries.
Yes what you are saying makes complete sense, but I only use my grip when I have on my 70-200mm or 100-300mm. When I use my primes, it is pure overkill to keep on my grip. In a quick change situation, i don't want to chance losing the seal gasket. However your point is correct, but why should I settle for a defective product, if in fact this is a defect.
Sounds like no one else has my issue.
battery, camera, gasket, grip, issue, k-1, k1, pentax help, photography, slot, troubleshooting
For Sale - Sold: D-BG6 Battery Grip for K-1 Mikesul Sold Items 2 07-05-2016 09:25 AM
Pentax BG6 battery grip JENSEN7474 Troubleshooting and Beginner Help 4 04-18-2016 09:47 PM
Black & White mine, mine, MINE !!! dcmsox2004 Post Your Photos! 7 09-22-2010 05:15 AM
I'll show you mine, if you show me yours! sawtooth235 Post Your Photos! 18 05-08-2009 07:33 AM
All times are GMT -7. The time now is 02:06 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
