On the third one, ISO is set at 3200, which isn't the best if you're looking for fine details.
Originally posted by Froth Ninja Just cropped to 1400 x 900 but pics are otherwise untouche
Are they cropped or you rather mean resized ? If they really are cropped, it means the spider might have been too small a target for the AF to work properly...
The first two also look underexposed, are you sure no negative exposure compensation or flash exposure compensation was set ? No matter what, the mostly white background with highlights should results in an underexposed picture and positive flash exposure compensation should be applied.
The lens was used at its longest focal length and largest aperture, which is about the worst combination for sharpness on any lens, and particularly on entry level zoom like the 18-55. Try stopping down to F/8 or F/11 and things should look sharper.
Originally posted by Froth Ninja ps - apart from M & green screen, I have no idea what the other settings on the dial are for & I can't find a menu in the manual
Green - Auto everything
P - Autoexposure
Av - Aperture Pritority, you set the aperture and the camera adjusts the speed and ISO
Tv - Shutter Priority, you set the shutter speed and the camera adjusts the aperture and ISO
TAv - Aperture/Shutter priority, you set both aperture and shutter speed and the camera adjusts the ISO
X - Flash sync, shutter speed is set to 1/180.
So, if you want to force the camera to use an aperture of F/8 to get a good sharpness, you can set it in Av mode and select F/8 with the dial.
