Originally posted by Saarepoiss Greetings shooters!
So i've been doing some research and i found out that
K-50 is best for its price. Some time after that i found
K-70 which is a bit better but not that much too, at my opinion. Now im struggling which camera i should buy and i hope that maybe i can get some of photographers advice. Things that im looking really forward doing with camera is nature picturing and less people picturing.
Now going to lens. Lens i found are here
Tamron AF 70-300 f/4.0-5.6 Di LD lens(
99€) with using
Tamron 17-50 f/2.8 (
299€). If you can recommend me better lens kit and keeping lens budget under 400€ then please.
thanks in advance!
K-70 due to everything about it vs. the K-50. Tamron 17-50 is excellent. For your quoted budget I guess that Tamronn 70-300 is going to be hard to beat. Read reviews of it before you get it so you know what to expect; the user reviews here on this site is an excellent way to learn before you buy.
You know what I might do instead? Keep that Tamron 17-50 but get a fast 50mm prime instead. DA50 1.8 should come in around 100 pounds I would think. Having a good fast lens that can take portraits nicely is worth a lot. That said, that 17-50 isn't a slouch in that department either.
There's about 100 different ways to answer this question! Good luck and keep coming back for ideas, advice, and showing off.
