07-19-2017, 04:39 PM   #1
CeciProAm's Avatar
My Pentax K3 Color Calibration/Representation is showing NONE
I know that I set my color representation to sRGB but suddenly it is showing: Uncalibrated
What have I done & how do I fix it?
Sometimes I love the complexity of this computer camera & other times I want to scream!!!
Thanks in advance for your help!~
ps. What have you found is the best setting for auto-focusing?
I spent an hour shooting chickens & the grass was in focus but not the chickens & no matter
what I adjusted it wouldn't stop focusing on the grass.
07-19-2017, 04:46 PM   #2
Otis Memorial Pentaxian
photolady95's Avatar
Moved to the correct forum. Price watch was not the right one.
07-19-2017, 04:47 PM   #3
CeciProAm's Avatar
QuoteOriginally posted by photolady95 Quote
Thank you.
I am apparently brain-dead today.
07-19-2017, 05:04 PM   #4
QuoteOriginally posted by CeciProAm Quote
Thank you. I am apparently brain-dead today.
You're welcome! I've had those days too, so I wondered why you put this thread, in Price watch. I was sure that's not where you wanted it.
07-19-2017, 05:15 PM   #5
K3
To fix it reset the camera to factory default.
I find AF works best for me if I use 9 pt AFC back button focus with focus priority set ( menu items 15 and 17 to 1 and 16 to 3) hold set to off (18 to 1).
07-19-2017, 05:48 PM   #6
CeciProAm's Avatar
Thank you. I will try that.
07-19-2017, 11:31 PM - 2 Likes   #7
Are you attempting to set the color space (menu>c3>21 Color Space) or something else? At what point are you seeing "uncalibrated".
Your camera has no good way of reading your mind and left to itself (auto setting), it will show that the AF system is lazy as well. It will set focus to the first thing on which it may easily do so. Setting back-button or AF-C will not change this. If you want the focus on chickens, you must direct the camera to focus on chickens. The analogy is that one's eyes focus on what one is looking at.
Assuming you are wanting to use PDAF with the optical viewfinder, your choices begin with:
AF-S (single) vs AF-C (continuous)
  • AF-S will lock focus once detected
  • AF-C will adjust constantly, even after focus is detected
Both approaches have suboptions.
Moving on you may choose:
Which focus points and how they are used. The full details are in the user manual, but the options are best experienced by exercising the feature. The most important consideration is whether you tell the camera which point to use or whether you let the camera choose for you.
Hint: Many on this site use a single focus point at center with AF-S, focus prioity.
07-21-2017, 02:30 PM   #8
CeciProAm's Avatar
Brilliant~! Thank you so much!!!
---------- Post added 07-21-17 at 02:31 PM ----------
Under properties/details
07-21-2017, 03:26 PM - 1 Like   #9
Oh...the file properties in Windows! I have seen that before, but couldn't remember the exact case where it happens, so I looked it up on the Web. What it means is that the file was saved by processing software without an embedded color profile or with one that Windows does not know about. The is an option to not embedded is supported in tools such as Lightroom. With your K-3, this also happens with in-camera JPEG when colorspace is set to AdobeRGB. Check to confirm your settings. Is it possible that the file was an in-camera conversion from RAW that was inadvertently saved as AdobeRGB?
Edit: The situation is actually a bit more complicated. The short answer is that the actual stored value in the EXIF is a number. From the EXIF specification v2.31...
If a color space other than sRGB is used, Uncalibrated (=FFFF.H) is set.
When tools read FFFF.H (decimal 65535) they display "Uncalibrated". The only other option is "1" (=sRGB). There is more...much more, but it would be confusing to dive deep into it here.
af-c, af-s, camera, chickens, color, coupon, focus, grass, pentax deals, pentax help, pentax k3 color, photography, savings, space, troubleshooting
Color Representation: Uncalibrated, sRGB vs Adobe RGB, washed out color etc. vabsh Digital Processing, Software, and Printing 11 05-19-2017 12:36 PM
Error Unread PM when there is none cali92rs Site Suggestions and Help 3 03-13-2017 01:40 PM
Abstract Half a Grill is Better than none. Tonytee Post Your Photos! 6 06-28-2016 05:23 PM
Question None of my "Sent" PM are saved? LaurenOE Site Suggestions and Help 2 05-29-2012 10:03 AM
Representation of reds in photos Elliot Pentax DSLR Discussion 10 02-27-2010 03:21 PM
All times are GMT -7. The time now is 05:03 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
