Originally posted by Joyce Keay Shooting live view the meter showed that 1/25 at f/5.6 was correct. When I switched to viewfinder the meter showed that I should be shooting at 1/60 at f5.6.
That is not unusual. The two views use two different metering systems. Both are evaluative, but the scene interpretations do not always result in the same numbers. In your case, the two are a full stop different for that photo. Normally, a full stop difference should result in obvious difference in brightness (2x). I am not familiar enough with Bridge to know whether or not there is a setting to optimize (shift histogram) on import, though something like that might explain the identical appearance.
