AF is a complicated thing. A lens that is f8 will have trouble focusing in low light much sooner than an f2.8 lens. This can cause apparent "slowing down" of AF. But this does not mean an f1 lens would focus super quickly. AF has sensor points, which have a certain sensitivity (expressed in f number). So a lens that is faster than that number might have less trouble focusing in low light, but it might have problems with AF preciseness, and DoF being so shallow it actually seems off. f2.8 seems like a sweet spot where the AF system gets enough light to be fairly effective in low light, but it also gives enough DoF and contrasts to work well.
AF also depends on the
focus throw and
AF motor (and the weight of the moving parts), which means some lenses will achieve focus more quickly than others. DFA 100mm macro, for example, has a long focus throw because of the macro range. The speed of the screwdrive motor is still just as fast as always, but the lens has more ground to cover. Something like DA 40mm XS, with really short focus throw and no macro range, will achieve focus sooner, despite having same aperture and using screwdrive. One of the new lenses with DC motor might be even faster
The other correlation is that lenses with fast aperture are usually premium lenses. As such, they might have a better AF motor or better build optimization. This can lead to the impression that lenses with faster aperture have faster AF. It is not
only due to the aperture, though.
So if you want fast AF, find a lens that fits:
a) Short focus throw (the amount you have to turn the focus ring to go from infinity to MFD)
b) Not macro (some macro lenses have "focus lock" button to prevent hunting in the wrong area)
c) Aperture between f2 and f4
d) Fast AF motor (screwdrive, SDM, DC, PLM in order; Third parties have motors like Piezo drive of Tamron or HSM of Sigma)
e) Modern lens coatings. Modern coatings allow good contrasts, good flare resistance, good colours, all of which can help the AF module.
f) Whether the AF assist light can help. In some cases the AF assist light can light up the subject so even a slower lens gets enough light. But with some lenses, the AF assist light is practically useless (particularly when focusing at super telephoto subjects or faraway landscapes)
e) There are reports that linear polarizing filters can confuse the AF. Circular polarizers are very common now, though. Just something to keep in mind if you use filters
Note that AF is only as fast as the weakest link. If you have no light, then even a fast AF motor wont help much. If you have fast aperture and good light, you might be limited by the cameras screwdrive engine.
Remember also that AF depends on the user. Are you using backbutton focusing? Are you using select AF point? AF.S, AF.C? Are you using Quickshift? Is the subject moving? Parallel to you or towards you? How is the light? AF is a tool to learn and then use to get what you need, not a tool to just blindly rely on.
Finally, some modern lenses are incredibly complicated. They even have programmable chips inside. In the case of some Sigma lenses, this seems to cause some AF problems on Kmount. Sigma 18-35mm, 30mm art, 35mm art all have really fast aperture and good focusing motors, but according to reports they seem to sometimes miss AF for
unknown reasons. So what good is speed if its unreliable?
Originally posted by beholder3 That is simply wrong nonsense. It can not, simply due to physics.
There we go. No need to wonder or think about it. Its "Due to physics" - all the answer anyone could ever want. When looking for a lens with fast AF, just ask yourself "which one is fastest, due to physics?"
