07-27-2017, 03:47 PM   #1
shaolen's Avatar
pentax Q10 hotshoe flash not firing
So I just got a Q10, everything is working brilliantly except hotshoe flahses. I first stuck an Olympus fl-36 (which works on my K-01) but it didn't work. Then I tried my pentax af500ftz and that still doesn't work. Is there a setting I need to tweek in order to get it to fire? I swear back when I had a Q7 it worked with external flashes. Also I have the latest firmware update. Any help appreciated
---------- Post added 07-27-17 at 02:50 PM ----------
Update. I also tried the af360fgz and no avail
07-27-2017, 04:09 PM   #2
I think you need to disable the built-in flash.
07-27-2017, 04:14 PM   #3
shaolen's Avatar
I've tried pushing the flash button and setting it to off. This did not work. I also tried having it set to flash on (flash auto is default)
07-27-2017, 05:41 PM   #4
No, a menu option specifically to turn off built-in flash -- it uses one or the other (built-in or hotshoe), so to enable hotshoe you disable internal. (Not just the back button to control flash options.)
07-27-2017, 05:50 PM   #5
shaolen's Avatar
On folder C2 #10 in the menu it has "flash when retracted" and I have that set to "do not discharge flash" (tired the other as well). Is there another part in the menu for flash? I'll keep looking
07-27-2017, 06:01 PM   #6
I think so. Can't find my Q(!) at the moment. (I moved recently, it is in a case somewhere.)
07-27-2017, 06:05 PM   #7
shaolen's Avatar
Interestingly it has now started working with the Olympus flash but still not the Pentax flash. It just doesn't make sense. But at least this was the flash I was wanting to use on it since its small
---------- Post added 07-27-17 at 05:06 PM ----------
If you find anything more out let me know. I appreciate your help. I'll update here if the pentax flashes work
07-27-2017, 06:20 PM   #8
Shutter speed has to be low enough also I suppose...
---------- Post added 07-27-17 at 09:34 PM ----------
Ok, found my Qs. I guess it was the regular flash button on the back I was thinking of. Flash needs to be set to OFF (which sounds weird to enable another kind of flash). But I guess you did that? If the Olympus flash works, then the hotshoe must be enabled and your Pentax isn't firing for some other reason.
07-27-2017, 07:49 PM   #9
enoeske's Avatar
QuoteOriginally posted by shaolen Quote
You need to use flash off, which disabled the built in flash and enables the hotshoe
07-27-2017, 07:59 PM   #10
shaolen's Avatar
Thanks for the help. thing is though that my Pentax flashes work on the k-01. Its just so strange. Oh well.
07-28-2017, 06:49 AM   #11
Yes, there are several possible reasons, but you can eliminate hotshoe being disabled if it works with other flashes. Probably has something to do with the fact that any non-Pentax flash is acting in "dumb" mode with hotshoe being a simple trigger while a Pentax flash is trying to communicate with the camera. I tend to use the hotshoe only to activate Cactus radio triggers, so I don't know the ins-and-outs of Pentax flash modes, etc...
camera, flash, hotshoe, pentax, pentax help, pentax q10 hotshoe, photography, q10, q10 hotshoe flash, troubleshooting, update
645Z not firing hotshoe or body PC connector - HELP rob8888 Pentax Medium Format 4 06-30-2016 10:19 AM
Flash not firing on K30 Fastback67 Troubleshooting and Beginner Help 5 05-24-2016 11:22 AM
Speedlight flash not firing at fast shutter speeds?? genesmasher Troubleshooting and Beginner Help 25 01-12-2016 10:15 AM
Spotmatic F: Flash on hotshoe isn't firing rocah360 Pentax Film SLR Discussion 15 07-14-2015 03:49 PM
Q10 arrives. Q10 vs Q comparison images. barondla Pentax Q 6 10-29-2012 09:58 PM
All times are GMT -7. The time now is 10:29 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
