Welcome to the Pentax Forums!
Your lens is:
- Manual focus, so you have to focus it using the focus ring
- Has aperture that cannot be controlled by the body, so you have to set it on the aperture ring. For this to work, make sure that the Aperture Enabled setting is set to true (instructions above).
- Will only stop down for exposure and DOF preview in M, X, and B modes
- Requires fully manual exposure settings for shutter, aperture, and ISO (no exposure automation)
- No P-TTL flash automation
To help you with focus and exposure tasks:
- There is a feature called 'focus confirm" where the AF system will tell you when the subject is in focus. There is also something called catch-in-focus that will release the shutter when the subject is in focus. Instructions are in user guide. Unfortunately you are limited to the center AF point only.
- Stop-down metering (similar in many ways to working with a vintage Pentax Spotmatic camera) is available for metering using either the green button or the DOF preview feature. The flow goes like this:
- Camera in M mode
- Set your desired aperture using the ring on the lens
- Set your desired ISO on the camera
- Frame and focus on your subject and press the green button. The camera will set the appropriate shutter speed using your choice of center-weighted or spot metering.
- Keep those settings and shoot at will until either your light or subject changes. There is no need to meter for each shot.
As an alternative to the green button, you may use the DOF preview lever to manually stop down the lens and use the viewfinder EV scale to adjust proper exposure using either the aperture ring or shutter speed wheel. I prefer to set the desired shutter speed first when using this method and move the aperture ring or ISO to center the pointer. This method is flexible and worth playing with. Exposure compensation is available for both methods for stop-down metering.
Note that all of the above is specific to K-mount lenses having electrically conductive mounts (no paint or anodizing). Adapted M42 lenses have a similar flow, but with a few quirks thrown in to make it more interesting.
If you encounter problems, the users on this site are incredibly helpful in troubleshooting and helping you get success.
