08-10-2017, 09:34 AM   #1
K3-II PKTriggercord Servermode Trouble
Does anyone out there have any experience or success using servermode to capture images?
Goal: To use servermode to automate my camera for the eclipse. Ideally I would like to script the shutter releases using the computers clock as a reference so I trigger the release with the proper settings at the exact moment I want.
Current Situation: I have servermode running and I can change ISO, Shutter, Aperture, and capture an image to the camera's buffer. The trouble is I don't know how to get the image from the buffer to my computer.
Details: I am using Lubuntu 17.04 on an old PC, using the command line to start servermode, then I open another command line instance and telnet into port 8888 (which is where servermode is listening). From here it accepts the commands to change ISO, Shutter, Aperture, and takes an image and the camera reacts properly. When I use the command "get_buffer" it prints out a bunch of ASCII characters to the terminal. I am guessing I could cut and paste these out and transcode them into a .dng but that seems wonky for a solution and won't work for my desired goal. I have tried using "get_buffer > file.dng" to save the output of the command but it doesn't seem to work. At this point I am beyond my knowledge of telnet.
Probably the problem: I really doubt telnet is the right tool for this, but that is the limit of my computer knowledge. I googled and it looks like netcat or putty might work but they seem like different flavors of telnet so I am not optimistic.
Possible Solutions: Well this is where I am at a loss, I am hoping someone out there with more computer experience than I have can suggest something other than telnet to access the port, issue commands, and save images. I am also open to totally different solution if anyone knows of another way to accomplish my goal.
I appreciate any help!
08-10-2017, 12:06 PM - 1 Like   #2
Firstly, telnet is ancient tech and should be banned (obligatory rant). Having said that, try the following:
get_buffer | tee filename.dng
This should prevent telnet from inserting escape characters into the output while also writing and saving the named file.
08-10-2017, 05:41 PM   #3
QuoteOriginally posted by jbinpg Quote
Thanks I will give that a try!
camera, command, computer, goal, image, pentax help, photography, port, shutter, trouble, troubleshooting
K70 with free 50mm 1.8 or K3 II? Kevriano Troubleshooting and Beginner Help 22 07-29-2017 10:52 PM
Pentax K3 II debug mode. acbc Pentax K-3 5 08-17-2016 10:27 PM
Mysterious sound from Pentax K3 II body even when not taking pictures dkg2707 Troubleshooting and Beginner Help 9 10-13-2015 09:06 PM
K3 mark II ? i83N Pentax DSLR Discussion 39 08-31-2014 05:23 PM
K3 vs. Df SteveM Pentax K-3 82 04-07-2014 11:44 AM
All times are GMT -7. The time now is 08:49 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
