08-12-2017, 11:19 AM   #1
autofocus inaccuracy, green spots on the mirror?
Hi all,
I am wondering if you have thoughts on this. My k-3 started having inconsistent autofocus about a year ago. I cleaned contacts , af sensor with no improvement.
Yesterday I looked at the mirror under microscope and found green residue (spots?) around the edge of the af mirror, according to this graph, number 3:
How Phase Detection Autofocus Works
Any ideas what's going on? Separation of some layers?
08-12-2017, 11:27 AM   #2
Green spots visible here
Sorry about the bad picture, it's difficult to capture the spots. They are behind the mirror, and the green residue is both in spots scattered around and on the edge of the smaller mirror, behind the front one.
QCAM-AA  Photo
08-12-2017, 11:42 AM   #3
Here's a better image of the sub mirror spots.
QCAM-AA  Photo
08-12-2017, 12:56 PM - 1 Like   #4
Otis Memorial Pentaxian
Welcome to the Pentax Forums!
Yes, those could affect AF performance, though probably be reducing precision and ability to detect the point of best focus. Misalignment of either the secondary or main mirror may also screw things up. If it were me, I have would have the camera professionally cleaned and mirror alignment adjusted, assuming, of course, that the spots are a foreign substance on the surface.
08-12-2017, 01:16 PM   #5
Hi,
I don't think they are a foreign substance. The spots appear around the edges too, it looks like some glue or coating separation. Precision wants 300usd for a repair so I am not sure if it is worth it. The af inaccuracy is consistent with the spots, I.e. Some work better than others.
08-12-2017, 06:47 PM - 1 Like   #6
QuoteOriginally posted by randomstuff Quote
Hi,
Looking more closely at your photo, it appears that the mirror has been exposed to moisture (cleaning solution?) at some point. Repair vs. replace...that is the old conundrum. If your K-3 is in otherwise excellent condition with low shutter count, repair might be a good option. If you can find a used body in similar condition with no known problems for $300, that would also work. More typical of market prices, KEH currently has an EX+ K-3 body with a 180 day warranty for $572.
08-12-2017, 08:26 PM   #7
I paid $599 for a new one 2 years ago, albeit from Canada and an unauthorized dealer. I wonder what happened with the prices since then. I tried cleaning the spots, but I am not sure if matters are improved, since it will take some time. It frankly looks like some adhesive that got flapped off from the mirror - edges are green and there are splash spots in the middle. I never did a wet cleaning on it. I might bring it over to a store and get it done if AF doesn't improve.
Thanks for the suggestions.
01-31-2018, 05:42 PM   #8
Some updates for the future users:
- store wouldn't clean it, citing mirror coating (silvering) being too delicate
- I ended up cleaning it with lens filters wrapped on cotton swabs with zeiss lens cleaning solution and isopropanol
- There are no visible scratches, not sure about microscopic ones
- The camera works much better, but I don't have a way to compare it to a new K-3 to compare if it is all good.
Overall, if I had a cheap camera, I would be happy to clean it at home, with proper care and proper tools (e.g. as mine above). If had a new camera worth >$600 that's not under warranty I would send it in to precision.
---------- Post added 01-31-18 at 06:43 PM ----------
af, autofocus, camera, care, home, k-3, lens, mine, mirror, pentax help, photography, precision, scratches, tools, troubleshooting
Landscape Green, Green and more Green AussieTrev Post Your Photos! 6 08-10-2018 03:26 PM
16-50 gross AF inaccuracy in PDAF - only in some AF points? rrstuff Pentax SLR Lens Discussion 9 11-19-2016 11:29 AM
Pentax 645N apperture mismatch and metering inaccuracy sniper29a Pentax Medium Format 12 04-10-2014 03:42 PM
AF inaccuracy? "Student" Pentax K-3 14 02-24-2014 12:00 PM
AF inaccuracy.. Fabian Pentax SLR Lens Discussion 7 12-11-2010 01:12 AM
All times are GMT -7. The time now is 09:31 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
